Re: Carb Fumes
[Re: MR_P_BODY]
#2756453
03/27/20 11:48 AM
03/27/20 11:48 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Fuel puddling in the intake. Power valve leaking. Too high fuel rest pressure, pushing past seats. I.E.fuel in the lines heats up sitting
Most likely cause, floats too high. Carb. and fuels gains temp. after its shut down. Fuel expands and spills in.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Carb Fumes
[Re: Rjmpro]
#2756617
03/27/20 08:19 PM
03/27/20 08:19 PM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
All of the above. And, do you have the exhaust cross-over blocked? If not, that can boil the gas out of even a good carb.
Master, again and still
