Re: Throttle cable help
[Re: '72CudaRacer]
#2756327
03/26/20 10:40 PM
03/26/20 10:40 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
Mancini has them
[Re: superwrench]
#2756844
03/28/20 12:51 PM
03/28/20 12:51 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
After more research and help from you guys on here, looks like Pioneer make a variety of "stock type" throttle cables to fit Mopars. The CA-8410 measures approx. 23", while the CA-8408 measures approx. 29". Both are available from a multitude of vendors, including Mancini, Autozone, O'reillys, Advance, ect. There may be other lengths available also. Thanks for the help. Brian
[Re: '72CudaRacer]
#2757121
03/29/20 09:22 AM
03/29/20 09:22 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
For what it is worth I used a Lokar cable with my tunnel ram because I couldn't use any conventional cable brackets. It has worked well and you can cut it to whatever length you need.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2757186
03/29/20 12:05 PM
03/29/20 12:05 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
For what it is worth I used a Lokar cable with my tunnel ram because I couldn't use any conventional cable brackets. It has worked well and you can cut it to whatever length you need. Mr three Before and after.
[Re: 68roadrunner]
#2758184
03/31/20 09:49 PM
03/31/20 09:49 PM
Bad340fish
Tulsa OK
my lokar pulled the lead end off it at the pedal, not sure i am a fan, after race day was shot Mine has been fine even though it is pulling two throttle bodies and the associated return springs. I have heard of that problem before and for that reason I carry a spare.
[Re: 68roadrunner]
#2758290
04/01/20 08:01 AM
04/01/20 08:01 AM
hemi-itis
my lokar pulled the lead end off it at the pedal, not sure i am a fan, after race day was shot I always keep and extra wire with me just as I did with the 6cyl. I go to the track a few time a year and the extra stress used to stress me,no mo
