Throttle cable help #2756325
03/26/20 10:37 PM
03/26/20 10:37 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I'm looking for the longest "factory style" throttle cable to fit a '72 Cuda. Mine has the square plastic mount at the firewall, but I also have a RB with a tall intake and dominator. A factory small block one is too short. I'm thinking that a 6 cylinder car would have had the longest cable from the factory? Would a pick up truck cable from that era also fit the fire wall? And where to find one?
Thanks, Brian
Re: Throttle cable help [Re: '72CudaRacer] #2756327
03/26/20 10:40 PM
03/26/20 10:40 PM
KATY TEXAS
csk Offline
csk  Offline
KATY TEXAS
Mancini has them
[img]https://live.staticflickr.com/65535/49699175113_7f39889fbc.jpg[/img]87379033_2843330729058951_8904448720599252992_o by Charlie Keel, on Flickr
512ci 9.7 compression, Stealth heads, 3.54gear A518 OD 4100lb,11.04@123 full street car trim
Re: Throttle cable help [Re: '72CudaRacer] #2756348
03/26/20 11:43 PM
03/26/20 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Slant 6 is the longest cable.. I use to make my cables(had the parts and crimper)
wave
Re: Throttle cable help [Re: '72CudaRacer] #2756356
03/27/20 12:01 AM
03/27/20 12:01 AM
KATY TEXAS
csk Offline
csk  Offline
KATY TEXAS
any parts store
Re: Throttle cable help [Re: '72CudaRacer] #2756372
03/27/20 12:36 AM
03/27/20 12:36 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
Ehrenberg sells them on eBay too.
Re: Throttle cable help [Re: '72CudaRacer] #2756837
03/28/20 12:30 PM
03/28/20 12:30 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I got the super long one from Mancini for my stroker in my '71. a tad long maybe, but it worked great with the tall cable bracket
Re: Throttle cable help [Re: superwrench] #2756844
03/28/20 12:51 PM
03/28/20 12:51 PM
Mooresburg, Tn
Mooresburg, Tn
After more research and help from you guys on here, looks like Pioneer make a variety of "stock type" throttle cables to fit Mopars. The CA-8410 measures approx. 23", while the CA-8408 measures approx. 29". Both are available from a multitude of vendors, including Mancini, Autozone, O'reillys, Advance, ect. There may be other lengths available also.
Thanks for the help. Brian
Re: Throttle cable help [Re: '72CudaRacer] #2757121
03/29/20 09:22 AM
03/29/20 09:22 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For what it is worth I used a Lokar cable with my tunnel ram because I couldn't use any conventional cable brackets. It has worked well and you can cut it to whatever length you need.
68 Barracuda Formula S 340
Re: Throttle cable help [Re: Bad340fish] #2757186
03/29/20 12:05 PM
03/29/20 12:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mr three smoke
Before and after.
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
Re: Throttle cable help [Re: Bad340fish] #2758170
03/31/20 09:31 PM
03/31/20 09:31 PM
ky
68roadrunner Offline
ky
my lokar pulled the lead end off it at the pedal, not sure i am a fan, after race day was shot
Re: Throttle cable help [Re: 68roadrunner] #2758184
03/31/20 09:49 PM
03/31/20 09:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine has been fine even though it is pulling two throttle bodies and the associated return springs. I have heard of that problem before and for that reason I carry a spare.
Re: Throttle cable help [Re: 68roadrunner] #2758290
04/01/20 08:01 AM
04/01/20 08:01 AM
hemi-itis Offline
hemi-itis  Offline
I always keep and extra wire with me just as I did with the 6cyl. I go to the track a few time a year and the extra stress used to stress me,no mo grin
1970 True V-Code 440 Six Pack, 4 speed
by tomsjack. 04/05/20 04:04 AM
Must see movie! Clark Gable racing at Indy
by Hemi_Joel. 04/05/20 02:30 AM
Hemi block engine mount
by hemienvy. 04/05/20 01:38 AM
1969 GTX convert 4 speed project wiw
by MI Mopar Works. 04/05/20 12:06 AM
Moparts Recent Posts
by solarguy. 04/05/20 05:32 AM
Best place for 1972 Dodge Charger carpet?
by migsBIG. 04/05/20 03:22 AM
Pushrod length Q?
by HOTMOPR. 04/05/20 02:45 AM
