Master cylinder bolt
#2756033
03/25/20 08:55 PM
03/25/20 08:55 PM
Posts: 2,363 PA
70HemiGTX
PA
I have 2 old master cylinders from my 70 GTX. NON power drum brakes. Neither was mounted on the car when I got it. One does not have any mounting bolts in it, the other has 4 bolts pressed in facing into the car's dash that would get nuts on them from under the dash and holding he clutch/brake pedal frame in place. Which is correct?
Re: Master cylinder bolt
[Re: 70HemiGTX]
#2756044
03/25/20 09:54 PM
03/25/20 09:54 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I have 2 old master cylinders from my 70 GTX. NON power drum brakes. Neither was mounted on the car when I got it. One does not have any mounting bolts in it, the other has 4 bolts pressed in facing into the car's dash that would get nuts on them from under the dash and holding he clutch/brake pedal frame in place. Which is correct? Nuts under the dash on a 69 RR,I would think they would be the same on a 70 GTX.
[Re: pushbutton]
#2756266
03/26/20 06:56 PM
03/26/20 06:56 PM
Posts: 1,328 VA
dragon slayer
VA
Non power drums stud in master cylinder. If it was power drum, the studs are on the booster so no studs in MC.
[Re: dragon slayer]
#2756320
03/26/20 10:28 PM
03/26/20 10:28 PM
Posts: 21,447 It's a dry heat
gtx6970
It's a dry heat
Non power drums stud in master cylinder. If it was power drum, the studs are on the booster so no studs in MC. yep
[Re: gtx6970]
#2756412
03/27/20 09:14 AM
03/27/20 09:14 AM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
getting to those suckers is one of the worst projects Ive done. If you're not young or smallish, take the seat out.
[Re: LimeliteAero]
#2756481
03/27/20 01:41 PM
03/27/20 01:41 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A flat-rater showed me a trick...a 24" 1/4" drive extension with a 1/2" deep swivel socket.
[Re: LimeliteAero]
#2756904
03/28/20 02:56 PM
03/28/20 02:56 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
getting to those suckers is one of the worst projects Ive done. If you're not young or smallish, take the seat out. This old fat boy agrees with you 100%.
[Re: 6PakBee]
#2756941
03/28/20 04:35 PM
03/28/20 04:35 PM
Posts: 2,363 PA
70HemiGTX
PA
[b][/b]Great. So I should put the master cylinder in before I even think of putting the dash in and or the seats or the shifter or anything else. Because I sure as heck can't twist like a pretzel any more. Not that I really could before. Thanks for the info though. I bought one of those new master cylinders off of ebay to put in the car. I know some of the plating isn't correct, but the shape of the lid is perfect. So that's a bonus. I'll transfer the studs over to the new master cylinder. Thanks everyone for the help.
