I have 2 old master cylinders from my 70 GTX. NON power drum brakes. Neither was mounted on the car when I got it. One does not have any mounting bolts in it, the other has 4 bolts pressed in facing into the car's dash that would get nuts on them from under the dash and holding he clutch/brake pedal frame in place. Which is correct?
