Page 3 of 3 1 2 3
Re: Steps to Convert a 1970 440 4bbl to a Six Pack Setu [Re: fastnos] #2755658
03/25/20 12:43 AM
03/25/20 12:43 AM
Pontiac, Illinois, USA
70-AAR-Cuda Offline
70-AAR-Cuda  Offline
Outstanding write up on the sixpak setup..... reminds me of the good old days...
Re: Steps to Convert a 1970 440 4bbl to a Six Pack Setu [Re: JohnRR] #2755805
03/25/20 01:24 PM
03/25/20 01:24 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Do yourself a favor and install a wideband gauge. I use the one from Innovate, and it really helps dial in the carbs. Be sure you have a quality fuel filter installed.
Be prepared when the secondaries open. I tuned a buddies 6 pack RB car. His secondaries were not working correctly and his timing was way off. I had assumed he knew how to drive, but the Doctor Jekyl & Mr Hyde nature of the outboards kicking in can be stunning with this induction set-up. The vacuum secondaries almost feel like they have a mind of their own compared to the mechanical secondary carbs. I never liked the vacuum carbs for that reason.
He completely wrecked the car some days later when he was at full throttle in 2nd and the rear tires broke loose. He panicked and it fishtailed out of control. Broke his daughter's arm in the crash too.
Re: Steps to Convert a 1970 440 4bbl to a Six Pack Setup [Re: Rob440Magnum] #2755902
03/25/20 04:09 PM
03/25/20 04:09 PM
Originally Posted by Rob440Magnum
According to Jim Schild's book, in 1970 the center carb was different depending if you had an automatic or 4 speed tranny.
R4375A - 4 speed carb
R4376A - automatic carb
R4383A - rear carb
R4382A - front carb
What was the difference on the center carbs?
What exactly is holley reproducing today for the 440 six pack setup?
My Challenger that I will be installing this on is a 4 speed car.
Thanks, Rob
Holley made more than those two List # for both 1970 CA and non CA six pack cars, according to Holley master parts catalog scope I remember seeing 3 or 4 more center carb List #s. Dang the EPA anyways rant
Mopar had Holley reproduce the 1971 non CA automatic six pack carbs is what I remember now shruggy They will have a -1 after the List number on those later carbs scope
Re: Steps to Convert a 1970 440 4bbl to a Six Pack Setu [Re: 70-AAR-Cuda] #2756071
03/26/20 12:20 AM
03/26/20 12:20 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The original post is from the good old days biggrin
Page 3 of 3 1 2 3
