Page 3 of 3 1 2 3
Re: Leaf Spring slider Tech [Re: justinp61] #2756520
03/27/20 03:42 PM
03/27/20 03:42 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Speedway Sales them .. Make sure at ride height your slider is sitting more towards the back... Even with a very tight shock settings my car will pull the slider forward 3". On an 1/8 mile pass...
https://youtu.be/ym-mamh17QQ
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Leaf Spring slider Tech [Re: topbrent] #2756540
03/27/20 04:42 PM
03/27/20 04:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
These are mounted too far forward and you can see the dr. side hit the ft. of the slider bracket.......should be 3/4's back or more to compensate for extension not compression...
Re: Leaf Spring slider Tech [Re: Thumperdart] #2756558
03/27/20 05:26 PM
03/27/20 05:26 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Has anyone tried the sliders that have the extention built into them? So they allow more separation during the launch.. Ill search the pic and info
https://www.lpracing.net/product-pa...Mm6sS4yywECvoidudbRbJzd-Eh3PbrHTc7YfMMwg
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Leaf Spring slider Tech [Re: HOTMOPR] #2756568
03/27/20 06:00 PM
03/27/20 06:00 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Re: Leaf Spring slider Tech [Re: HOTMOPR] #2756584
03/27/20 06:40 PM
03/27/20 06:40 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have never seen anything like these before eek
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Leaf Spring slider Tech [Re: hemi-itis] #2756654
03/27/20 10:06 PM
03/27/20 10:06 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
At 219.00 each , I probably won't be seeing them up close either.
Re: Leaf Spring slider Tech [Re: tubtar] #2757461
03/30/20 01:01 AM
03/30/20 01:01 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
They are certainly interesting. The spring perches on that car were very, very tall as well!
Alan Jones
Re: Leaf Spring slider Tech [Re: LA360] #2757605
03/30/20 02:11 PM
03/30/20 02:11 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My Brackets....After I cleaned em up, they bolt on my Dakota
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Leaf Spring slider Tech [Re: Adobedude] #2758574
04/01/20 07:23 PM
04/01/20 07:23 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
https://www.facebook.com/kevin.vannoy.5/videos/10216473625378086/
So has anyone tried these sliders yet?
They look interesting but will they work? Any thoughts. I am thinking they would not act as quickly as the laid down sliders. Not sure if that is good or bad?
Re: Leaf Spring slider Tech [Re: XXHEMI] #2758780
04/02/20 10:12 AM
04/02/20 10:12 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
They should plant quicker and have a lot more extention. Depending on shock settings of course. Id like to try a set but cant justify the costs right now. With whats going on..
Re: Leaf Spring slider Tech [Re: XXHEMI] #2758794
04/02/20 10:39 AM
04/02/20 10:39 AM
hemi-itis Offline
hemi-itis  Offline
On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce rolleyes
Re: Leaf Spring slider Tech [Re: hemi-itis] #2758796
04/02/20 10:41 AM
04/02/20 10:41 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I run calverts slanted sliders..
Re: Leaf Spring slider Tech [Re: HOTMOPR] #2758799
04/02/20 10:54 AM
04/02/20 10:54 AM
hemi-itis Offline
hemi-itis  Offline
I'd bet the hardware was correct the 1st time also............ whistling
Re: Leaf Spring slider Tech [Re: hemi-itis] #2758801
04/02/20 10:58 AM
04/02/20 10:58 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Yes sir... llol
Re: Leaf Spring slider Tech [Re: HOTMOPR] #2758840
04/02/20 12:34 PM
04/02/20 12:34 PM
hemi-itis Offline
hemi-itis  Offline
On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce rolleyes [/quote]
I run calverts slanted sliders.. [/quote]
I'd bet the hardware was correct the 1st time also............ whistling [/quote]
Yes sir... llol [/quote]
I always do it the long/hard way.Very expensive learning curve and I'm not in the 8's..................Yet whistling
Wonder if the slanted is better than the level??????????
Page 3 of 3 1 2 3
