1966 Sport Fury disc brake up grade #2755610
03/24/20 09:44 PM
03/24/20 09:44 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Just bought a really nice Sport Fury with Front drums.It is a Turquoise with Black Buckets and Console with Factory A/C powered by a 318 Poly
What do I need to up grade the front brakes. Thanks Guys
Re: 1966 Sport Fury disc brake up grade [Re: 68GTS383] #2755656
03/25/20 12:26 AM
03/25/20 12:26 AM
AndyF Offline
AndyF  Offline
That is a C body correct? I think the 1973 C body disc brake knuckles are the best way to go. I have a couple pair of those out in the shop left over from a project I worked on. I tried to sell them at a couple of swap meets but nobody was interested so I still have them.
Re: 1966 Sport Fury disc brake up grade [Re: AndyF] #2758225
03/31/20 10:52 PM
03/31/20 10:52 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
The 73 C Body front disc upgrade is the way to go. Only old parts needed are the knuckles, and if desired, the backing plates. Get everything else new. The C Body sites have more details but it is all bolt in.
https://www.forcbodiesonly.com/mopar-forum/threads/65-fury-disc-brake-conversion-advice.28497/
one of many discussions.
Only other issue is the dual diaphragm brake booster is hard to find.
Mark
Re: 1966 Sport Fury disc brake up grade [Re: michiganhotrod1] #2759214
04/03/20 01:43 AM
04/03/20 01:43 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Mark
With a console shift you can use the later style booster from the 73 if you can't find the dual diaphragm late 60's style.
The later booster is bigger in diameter and will interfere with a column shift linkage. Not an issue with the console shift linkage.
Kevin
