BREAK IN OIL #2755398
03/24/20 11:32 AM
03/24/20 11:32 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Anyone use the Summit 30wt break in oil?
Real Men shift for themselves
Re: BREAK IN OIL [Re: 1DGEMAN] #2755438
03/24/20 12:58 PM
03/24/20 12:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Can't answer directly, but a joke:
A single number, or the 1st number before the 'W', is the time in seconds for oil pressure to reach the last bearing in the engine.
5W30: 5 seconds
20W50: 20 seconds
50: 50 seconds
Boffin Emeritus
Re: BREAK IN OIL [Re: polyspheric] #2755445
03/24/20 01:13 PM
03/24/20 01:13 PM
Kirkland, Washington
Pacnorthcuda Offline
5W30: 5 seconds
20W50: 20 seconds
50: 50 seconds
That’s funny. Interesting way of looking at it! I once did a comparison of several oils by putting them in identical jars then freezer overnight. Pretty damn interesting the next day.....30w (which was damn common in the 70’s) is REALLY thick when cold!!!
Re: BREAK IN OIL [Re: Pacnorthcuda] #2755484
03/24/20 03:11 PM
03/24/20 03:11 PM
I remember hearing some sort of expert comment about oil weight ratings being based on the pour rate time for a quart of oil to go through a screen or siv at the same temps., lighter weight oil went through it quicker than the heavier weight rated oils did work
I can see the differences in 5W20 Wt. compared to 30Wt on the time it talks my mechanical oil pressure gauge to make pressure with the same outside air temps. Lighter weight rated oil is faster on making oil pressure to the gauge cold up
Re: BREAK IN OIL [Re: Cab_Burge] #2755494
03/24/20 03:49 PM
03/24/20 03:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Exactly.
Boffin Emeritus
Re: BREAK IN OIL [Re: polyspheric] #2755543
03/24/20 06:00 PM
03/24/20 06:00 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Valid points on oil viscosity. i bought some 10w30 break in oil.
Re: BREAK IN OIL [Re: 1DGEMAN] #2755561
03/24/20 07:28 PM
03/24/20 07:28 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
The question is, Roller or Slider? My 410 stroker Magmumn 5.9 roller cam will get a 15W40 (Delo LE or Rotella T5) for the first and second oil change. Then 5W30 Syn blend.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
