cross hatch #2754981
03/23/20 12:08 PM
03/23/20 12:08 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
if replacing rings and cross hatch looks good does it still need to be re hatched.
Re: cross hatch [Re: bonefish] #2754986
03/23/20 12:20 PM
03/23/20 12:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have seen it recommended that deglazing is not necessary. But I have never done it. I have always run something through it.That being said I wouldn't be to rough with it unless you are running plain cast iron rings.
Re: cross hatch [Re: B1MAXX] #2754988
03/23/20 12:28 PM
03/23/20 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always hit the bores with a hone... I should say deglased.. I have always called it a hone and I know
the difference
wave
Re: cross hatch [Re: bonefish] #2755284
03/24/20 12:11 AM
03/24/20 12:11 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
i
ring type will give bore finish needed !
Re: cross hatch [Re: bonefish] #2755477
03/24/20 02:54 PM
03/24/20 02:54 PM
I would use some 320 grit sandpaper between cylinder hone stones and the cylinder walls (with a lot of pressure on the stones)with either kerosene or jet A fuel as a lube and make no more than 4 complete up and down strokes in each cylinder and then clean the holy be holy on the cylinder wall finish to remove any grit or debris left wrench up twocents Change the paper after two cylinders or use them only once depending on what you see and like wrench up scope
Re: cross hatch [Re: Cab_Burge] #2755487
03/24/20 03:22 PM
03/24/20 03:22 PM
Washington
madscientist Offline
Washington
Moly rings were made specifically to go into bores that are NOT honed. Put the rings in dry ( a little assembly lube on the skirts and NONE on the rings) and run it. They will seal.
Re: cross hatch [Re: madscientist] #2755631
03/24/20 10:50 PM
03/24/20 10:50 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Cough cough.......huh???
Re: cross hatch [Re: Pacnorthcuda] #2755634
03/24/20 11:00 PM
03/24/20 11:00 PM
Washington
Washington
What part is giving you trouble.
Re: cross hatch [Re: madscientist] #2755649
03/24/20 11:35 PM
03/24/20 11:35 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
From https://www.extrudehoneafm.com/
Depending on the application, instructions for your new pistons will specify that the cylinder needs a bore and hone, bore/replace, or deglaze/hone. More often than not, you will need to hone your cylinder when replacing the piston rings. That is because honing creates small crosshatches in the surface of the cylinder, to allow the wall of the component to retain oil and provide lubrication for the piston ring.
Even though the instructions for the new piston may specify that honing your cylinder is required, you can also manually check and see if your cylinder requires it. Simply deglaze the cylinder with hot water and SOS pads to thoroughly clean it, and then look inside. If you can still see the original hone marks (cross-hatching) then you likely will not need to hone the cylinder. If those cross hatches have worn down, you will need to have the cylinder honed to allow proper lubrication of the piston ring.
