BREAK IN OIL
#2755398
03/24/20 11:32 AM
03/24/20 11:32 AM
Posts: 608 TN
1DGEMAN
TN
Anyone use the Summit 30wt break in oil?
Real Men shift for themselves
Re: BREAK IN OIL
[Re: 1DGEMAN]
#2755438
03/24/20 12:58 PM
03/24/20 12:58 PM
Posts: 4,213 New York
polyspheric
New York
Can't answer directly, but a joke: A single number, or the 1st number before the 'W', is the time in seconds for oil pressure to reach the last bearing in the engine. 5W30: 5 seconds 20W50: 20 seconds 50: 50 seconds
Boffin Emeritus
Re: BREAK IN OIL
[Re: polyspheric]
#2755445
03/24/20 01:13 PM
03/24/20 01:13 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Can't answer directly, but a joke: A single number, or the 1st number before the 'W', is the time in seconds for oil pressure to reach the last bearing in the engine. 5W30: 5 seconds 20W50: 20 seconds 50: 50 seconds That’s funny. Interesting way of looking at it! I once did a comparison of several oils by putting them in identical jars then freezer overnight. Pretty damn interesting the next day.....30w (which was damn common in the 70’s) is REALLY thick when cold!!!
Re: BREAK IN OIL
[Re: Pacnorthcuda]
#2755484
03/24/20 03:11 PM
03/24/20 03:11 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I remember hearing some sort of expert comment about oil weight ratings being based on the pour rate time for a quart of oil to go through a screen or siv at the same temps., lighter weight oil went through it quicker than the heavier weight rated oils did ![work work](/ubbthreads/images/graemlins/custom/work.gif) I can see the differences in 5W20 Wt. compared to 30Wt on the time it talks my mechanical oil pressure gauge to make pressure with the same outside air temps. Lighter weight rated oil is faster on making oil pressure to the gauge cold ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: BREAK IN OIL
[Re: Cab_Burge]
#2755494
03/24/20 03:49 PM
03/24/20 03:49 PM
polyspheric
New York
oil weight ratings being based on the pour rate time Exactly.
Boffin Emeritus
Re: BREAK IN OIL
[Re: polyspheric]
#2755543
03/24/20 06:00 PM
03/24/20 06:00 PM
Posts: 608 TN
1DGEMAN
TN
Valid points on oil viscosity. i bought some 10w30 break in oil.
Re: BREAK IN OIL
[Re: 1DGEMAN]
#2755561
03/24/20 07:28 PM
03/24/20 07:28 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
The question is, Roller or Slider? My 410 stroker Magmumn 5.9 roller cam will get a 15W40 (Delo LE or Rotella T5) for the first and second oil change. Then 5W30 Syn blend.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
