Re: odd E440 HP block - no casting number ?????
[Re: fastmark]
#2755319
03/24/20 07:48 AM
03/24/20 07:48 AM
Posts: 1,336 VA
dragon slayer
VA
What year is the block 66 or 68? I have seen older blocks stamped on pad, despite being over counter or race. Current one is a 62 block stamped B 440, and has Bryant stamped along rear ears. So who knows what builders were doing in the day.
No vin on your block either?
[Re: dragon slayer]
#2755428
03/24/20 12:29 PM
03/24/20 12:29 PM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
cast 8*5*68 - the VIN's been ground off - looks like it was a full 13-digit it also has the early mounting bosses on the front of the block any early 440 a-bodies use the 383 mounts? it is .040" over & had an old Sunrey/Eagle stroker crankshaft in it
[Re: 6bblgt]
#2755623
03/24/20 10:22 PM
03/24/20 10:22 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
maybe a 68 GSS OR ONE OF 6 GTS 440 CARS
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2755626
03/24/20 10:32 PM
03/24/20 10:32 PM
Posts: 29,656 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Yellow paint peeking out all over, yellow was used for industrial engines for years. Edit - An online search for '440 industrial' lead to this page - https://www.440source.com/blockinfo.htm
[Re: A12]
#2756029
03/25/20 08:41 PM
03/25/20 08:41 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
What does the upside down A and the B mean on the pad, I forget?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2756218
03/26/20 03:51 PM
03/26/20 03:51 PM
6bblgt
Las Vegas, NV
the "A" "B' and "C" stampings on the top pad are in reference to the cylinder bores sizes as referenced by the painted "A" "B" "C" "D" on the skirt of the block as seen in A12's pics above, many small blocks have them stamped on the pan rail for each cylinder a factory 0.020" over block would be a rare occurrence & I have yet to find a picture of a "yellow" MOPAR industrial engine, got pics? what kind of acid could be used to wash the VIN surface in an attempt to find the missing VIN?
