odd E440 HP block - no casting number ????? #2755301
03/24/20 04:58 AM
03/24/20 04:58 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
has anyone seen a 440 block like this? scope
no casting number & odd ribbing like a 413 industrial engine shruggy
moparts E440 8 5 68.jpgmoparts E440.jpgmoparts E440 HP.jpgmoparts E440 12 7 HP.jpg
Re: odd E440 HP block - no casting number ????? [Re: 6bblgt] #2755310
03/24/20 07:23 AM
03/24/20 07:23 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is odd. It’s been worked on and maybe raced. It has main studs. Is it std bore? I doubt if it is an over the counter block with E440 stamping, though. Any chance it could have come from a dealer like Mr Norm?
Re: odd E440 HP block - no casting number ????? [Re: fastmark] #2755319
03/24/20 07:48 AM
03/24/20 07:48 AM
VA
dragon slayer Offline
VA
What year is the block 66 or 68? I have seen older blocks stamped on pad, despite being over counter or race. Current one is a 62 block stamped B 440, and has Bryant stamped along rear ears. So who knows what builders were doing in the day.
No vin on your block either?
Re: odd E440 HP block - no casting number ????? [Re: dragon slayer] #2755428
03/24/20 12:29 PM
03/24/20 12:29 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
cast 8*5*68 - the VIN's been ground off - looks like it was a full 13-digit
it also has the early mounting bosses on the front of the block work any early 440 a-bodies use the 383 mounts?
it is .040" over & had an old Sunrey/Eagle stroker crankshaft in it
Re: odd E440 HP block - no casting number ????? [Re: 6bblgt] #2755623
03/24/20 10:22 PM
03/24/20 10:22 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
maybe a 68 GSS OR ONE OF 6 GTS 440 CARS
Re: odd E440 HP block - no casting number ????? [Re: davesmopars] #2755626
03/24/20 10:32 PM
03/24/20 10:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yellow paint peeking out all over, yellow was used for industrial engines for years.
Edit - An online search for '440 industrial' lead to this page - https://www.440source.com/blockinfo.htm
Re: odd E440 HP block - no casting number ????? [Re: Alaskan_TA] #2755667
03/25/20 01:43 AM
03/25/20 01:43 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks for the link. up That may help with a 440 complete engine that I have that I was told was "an over the counter 440 HP2 block purchased in 1969 for an Excalibur Kit Car". It is stamped E 440, 3 28, HP2 and no VIN and an odd I.D. plate that is nail riveted to the bell housing that read E440. I contacted GG years ago on it and he felt it was an over the counter '69 and not a marine or industrial engine. Later I contacted a former Dodge engineer that was in charge of Dodge engine development from 1962 - 2005 and he checked with others and the conclusion was also that it was an over the counter 440 engine. I still wondered if it might be an industrial engine but am agreeing with the others that it is NOT an industrial engine after seeing these blocks below and this from 440 Source's web page:
"One other addendum.. Some 413/426/440 blocks commonly known as "industrial / cold weather or heavy duty truck" blocks have another pattern all together, with even more reinforcements. Shown below is one of these."
440 multi rib INDUSTRIAL cold weather block.jpg440 ribbed standard and HP Block 1969 on 001.jpgDSC01912.JPGDSC01935.JPG
Re: odd E440 HP block - no casting number ????? [Re: 6bblgt] #2755974
03/25/20 06:20 PM
03/25/20 06:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
shock Pearl Harbor Day assembly date on the OP block.
Re: odd E440 HP block - no casting number ????? [Re: A12] #2756029
03/25/20 08:41 PM
03/25/20 08:41 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
What does the upside down A and the B mean on the pad, I forget?
JB Rhinehart, Realist
A-Body's RULE!
Re: odd E440 HP block - no casting number ????? [Re: Rhinodart] #2756207
03/26/20 03:11 PM
03/26/20 03:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Right side up, sideways, upside down - no change in meaning. A is called out in the 1969 TSB page at https://www.hamtramck-historical.com/images/TSBs/1969/D69-25-1%20page7.jpg
The only mention there of a B is for small blocks though.
Re: odd E440 HP block - no casting number ????? [Re: Alaskan_TA] #2756217
03/26/20 03:44 PM
03/26/20 03:44 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
i worked on a 440 just like that years a go,it was in a Century boat. i was told the owner bought it new and never been worked on,it had factory 2-4bbl and was reverse crank rotation and camshaft gear drive.
Re: odd E440 HP block - no casting number ????? [Re: Rhinodart] #2756218
03/26/20 03:51 PM
03/26/20 03:51 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
the "A" "B' and "C" stampings on the top pad are in reference to the cylinder bores sizes as referenced by the painted "A" "B" "C" "D" on the skirt of the block
scope as seen in A12's pics above, many small blocks have them stamped on the pan rail for each cylinder
a factory 0.020" over block would be a rare occurrence & I have yet to find a picture of a "yellow" MOPAR industrial engine, got pics?
what kind of acid could be used to wash the VIN surface in an attempt to find the missing VIN?
Re: odd E440 HP block - no casting number ????? [Re: 6bblgt] #2756228
03/26/20 04:21 PM
03/26/20 04:21 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
here's a top pad on a MARINE engine assembled at the Marysville plant VS. the AUTOMOTIVE assemblies from the Trenton plant above
anyone know what plant assembled industrial engines? or have a top pad pic of an industrial RB engine?
the right-hand rotation block from this pair is running around Las Vegas in a '69 Dart - I'll see if I can chase it down & get a pic
What does this washer bottle fit?
by sixpackbird. 06/06/20 11:52 AM
Fully informed rental vehicle buying?
by 360view. 06/06/20 10:37 AM
70 Bee Fender Emblem Placement
by HILOGTX. 06/06/20 10:29 AM
Moparts Recent Posts
1970 Challenger R/T factory sunroof restoration
by SportFuryS/23383. 06/06/20 11:54 AM
440 Stroker Engine Problems In A 1967 Plymouth Fury
by SportFuryS/23383. 06/06/20 11:47 AM
1974 dodge dart - $800
by Mopar1970440. 06/06/20 11:44 AM
