new build )) #2754916
03/23/20 10:04 AM
03/23/20 10:04 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
Well, She's ready for the dyno. 572 b1 originals, K1 crank, Molanr rods, wiesco flat tops 13.8:1 , .800 ish cam (2) ATM 1050 cfm E85 carbs on a hogans sheet metal intake. Hopefully it makes 850 - 900 on the dyno.
Sorry for the poor pics.
Re: new build )) [Re: e85mope] #2754918
03/23/20 10:13 AM
03/23/20 10:13 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
ganster
Re: new build )) [Re: e85mope] #2754935
03/23/20 10:32 AM
03/23/20 10:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I def wouldn’t be happy with 850-900 outta that!!
Re: new build )) [Re: fast68plymouth] #2754943
03/23/20 10:49 AM
03/23/20 10:49 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Nice!! ...which block you using??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: new build )) [Re: jughed] #2754947
03/23/20 11:00 AM
03/23/20 11:00 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
World products. With MOPAR cast in the side.
Re: new build )) [Re: jughed] #2754950
03/23/20 11:02 AM
03/23/20 11:02 AM
UK
rb446 Offline
rb446  Offline
UK
Should do, we've got a guy here with a 580 wedge, 12.5:1, -13's, .765 roller, Indy t-ram with twin Doms, making very close to 900 according to his weight/mph.
nice motor up
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: new build )) [Re: e85mope] #2754951
03/23/20 11:03 AM
03/23/20 11:03 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
another angle
Re: new build )) [Re: e85mope] #2755618
03/24/20 10:05 PM
03/24/20 10:05 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Good luck with the build luck
Re: new build )) [Re: e85mope] #2755625
03/24/20 10:28 PM
03/24/20 10:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like it should be a great bracket engine up
wave
Re: new build )) [Re: fast68plymouth] #2755664
03/25/20 01:31 AM
03/25/20 01:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
I"ve built one B1 bracket motor so far, 4.250 stroke with a 4.495 bore, cast B1 single four barrel Dominator intake with a 1450 CFM DAMB best gas carb, that combination made 920 at around 7000 RPM in Boise, ID 3 to 5 yrs ago. It was not a all out go fast race motor, built to repeat and be low maintenance up
I hope yours does that for you up
