How to identify a’67 Hemi Coronet R/T?
#2754635
03/22/20 04:55 PM
03/22/20 04:55 PM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
Hello! If I were to find a car in a barn, besides the VIN, what are things unique to hemi R/Ts, please? Asking for a friend...
Did they use an 8 3/4? We’re power brakes an option?
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
Re: How to identify a’67 Hemi Coronet R/T?
[Re: dragon slayer]
#2754907
03/23/20 09:35 AM
03/23/20 09:35 AM
Posts: 10,704 North Dakota
6PakBee
North Dakota
Yes power brakes and power disc available. Dana for 4 speed, but that was not hemi specific as 440 had them also. Hemi Emblems, believe torque boxes, and hemi type k-frame mounts. Vin for sure. All 1967 B-Body power disc brakes used the offset "Hemi" booster. If you got the Hemi with the Torqueflite, you got manual drum brakes and an 8 3/4. If you went with the 4-sp, power front discs and the Dana were mandatory options. As to Hemi only, yes, torque boxes and the Hemi K-frame were necessary. 3/8" fuel lines rather than 5/16". The item most overlooked in a clone or an imposter is the plate welded to the rear floor pan that the pinion snubber contacts.
[Re: 6PakBee]
#2754987
03/23/20 12:21 PM
03/23/20 12:21 PM
4boxers4
Heart of Ohio
Thank you. What is specific about the Hemi K frame, please? Aren’t the block mounting points similar on all RB motors? Maybe skid plate or something?
[Re: 4boxers4]
#2755053
03/23/20 02:45 PM
03/23/20 02:45 PM
6PakBee
North Dakota
Thank you. What is specific about the Hemi K frame, please? Aren’t the block mounting points similar on all RB motors? Maybe skid plate or something? Hemi doesn't use the B/RB mount bracket style that bolts to ears on the block. Totally different arrangement that bolts to the sides of the block. Google some pictures and the difference is obvious.
[Re: 6PakBee]
#2755150
03/23/20 06:12 PM
03/23/20 06:12 PM
Posts: 21,403 It's a dry heat
gtx6970
It's a dry heat
Yes power brakes and power disc available. Dana for 4 speed, but that was not hemi specific as 440 had them also. Hemi Emblems, believe torque boxes, and hemi type k-frame mounts. Vin for sure. All 1967 B-Body power disc brakes used the offset "Hemi" booster. If you got the Hemi with the Torqueflite, you got manual drum brakes and an 8 3/4. If you went with the 4-sp, power front discs and the Dana were mandatory options. As to Hemi only, yes, torque boxes and the Hemi K-frame were necessary. 3/8" fuel lines rather than 5/16". The item most overlooked in a clone or an imposter is the plate welded to the rear floor pan that the pinion snubber contacts. You certain about the 4 spd getting disc brakes as standard? Im not
[Re: gtx6970]
#2755335
03/24/20 08:35 AM
03/24/20 08:35 AM
6PakBee
North Dakota
Yes power brakes and power disc available. Dana for 4 speed, but that was not hemi specific as 440 had them also. Hemi Emblems, believe torque boxes, and hemi type k-frame mounts. Vin for sure. All 1967 B-Body power disc brakes used the offset "Hemi" booster. If you got the Hemi with the Torqueflite, you got manual drum brakes and an 8 3/4. If you went with the 4-sp, power front discs and the Dana were mandatory options. As to Hemi only, yes, torque boxes and the Hemi K-frame were necessary. 3/8" fuel lines rather than 5/16". The item most overlooked in a clone or an imposter is the plate welded to the rear floor pan that the pinion snubber contacts. You certain about the 4 spd getting disc brakes as standard? Im not I have an original 1967 Plymouth salesman's book, that is what my comment is based on. And no, I never said that disc brakes with a 4-spd were "standard", I used the term the book uses "mandatory option". If it comes down to it I'll scan that page out of the book.
[Re: rapom]
#2756147
03/26/20 11:09 AM
03/26/20 11:09 AM
4boxers4
Heart of Ohio
Thanks guys, I appreciate it. The front end is missing on the car but the k member and offset booster are there. The VIN is also intact but the car has an 8 3/4 under it. I am thinking maybe the Dana could have been scavenged at some point, and this is to keep it rolling.
[Re: 1970GTX]
#2756538
03/27/20 04:40 PM
03/27/20 04:40 PM
6PakBee
North Dakota
Is the fender tag still there? Unfortunately a fender tag on a '67 doesn't guarantee that the car is genuine. As there is no VIN on a '67 fender tag, it could have come from another car.
