Leaf Spring slider Tech
#2754467
03/22/20 10:57 AM
03/22/20 10:57 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Something I've wanted to do for a while...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Leaf Spring slider Tech
[Re: WHITEDART]
#2754469
03/22/20 11:04 AM
03/22/20 11:04 AM
WHITEDART
bean town ....Ca
Couple inches lower now.. I just need some place other than the freeway to race it
[Re: mopar_man619]
#2754738
03/22/20 08:06 PM
03/22/20 08:06 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Very slick. I never considered this option when I put mine on...........but I like the way you think.
[Re: mopar_man619]
#2754783
03/22/20 09:58 PM
03/22/20 09:58 PM
WHITEDART
bean town ....Ca
looks good! we got em on the orange dart. they are on the frame rail though and not recessed like yours! the orange nova says you're gonna need more than that but hey don't shoot the messenger lol.... Eventually he will have to stop hiding
[Re: WHITEDART]
#2755006
03/23/20 01:03 PM
03/23/20 01:03 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I am looking forward to seeing the results.
"Just a Bracket car dressed up like a streetcar"
[Re: misfired]
#2755208
03/23/20 08:41 PM
03/23/20 08:41 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Great way to get it lower. Be ready to tighten the rear shocks!!! They might be on the short side now...........
[Re: one bad fish]
#2755220
03/23/20 09:18 PM
03/23/20 09:18 PM
Posts: 4,669 Wichita
GY3
Wichita
Wow, what a beautiful Barracuda!
[Re: nasty68]
#2755225
03/23/20 09:31 PM
03/23/20 09:31 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
Are you guys bolting or welding your sliders to the frame rails? I welded mine
[Re: nasty68]
#2755277
03/23/20 11:52 PM
03/23/20 11:52 PM
WHITEDART
bean town ....Ca
Are you guys bolting or welding your sliders to the frame rails? . Mine Bolt in I am able to put shims under each slider as needed to help get the car to scale the way I want
[Re: WHITEDART]
#2755758
03/25/20 11:48 AM
03/25/20 11:48 AM
Posts: 116 Eastern Shore of Maryland
nasty68
Are you guys bolting or welding your sliders to the frame rails? . Mine Bolt in I am able to put shims under each slider as needed to help get the car to scale the way I want Before recessing them into the frame, how did you have them mounted? Were they bolted to a plate that was attached to the frame rail? I am getting ready to mount mine sometime this week and i am trying to figure out the best way to do it.
68 dart, 383, 727 2013 Jeep JKU Sahara
[Re: MR_P_BODY]
#2755777
03/25/20 12:32 PM
03/25/20 12:32 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I like that you moved the front perch up along with mounting the sliders to the frame. It seems to have a negative effect on 60' when the spring gets tipped up at the rear mounting point and is not longer close to or parallel with the chassis centerline. I moved the front eye of the leaf spring into the upper hole to compensate for the extreme angle created by replacing the shackles with sliders welded to the frame. The idea of shimming to weights right is cool too.
Thanks for sharing!
[Re: misfired]
#2755808
03/25/20 01:29 PM
03/25/20 01:29 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
How do the sliders effect handling, or are they for drag racing only?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
