LCA's worn out/junk? #2753389
03/19/20 09:20 AM
03/19/20 09:20 AM
IL
8
83hurstguy Offline OP
IL
I am new to Mopar, we are working through our first front suspension rebuild on a '70 Challenger. We put new bushings in the LCA, put it back on the car, and realized we still have a bunch of play out near the spindle.
Take a look at this video... the LCA hole appears to be oversized where the torsion bar sleeve passes through it, and it has slop there. Is this a common issue with these? I'm assuming it's not fixable, the arm is junk and we'll need a replacement? There's no play from the new bushing that's on the pin in the K-member from what we can tell, it's all in this area.
Thanks in advance!
Re: LCA's worn out/junk? [Re: 83hurstguy] #2753392
03/19/20 09:37 AM
03/19/20 09:37 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Pretty common. The LCA isn't "worn out". It was just built that way. (sloppy) Those two pieces don't move independently from each other once the ride height it set. My Dart LCA was the same way. I welded a small strap to the back side to tighten things up. Not sure that it actually does much of anything but it made me feel better. Once there is a load on the LCA from the torsion bars and the strut rod is installed, my guess is that movement will go away.
Re: LCA's worn out/junk? [Re: burdar] #2753398
03/19/20 10:16 AM
03/19/20 10:16 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I just had to pull one because the bushing had failed. A friend had a NOS piece, with the stock tag still on it. Similar slop. I think your piece is fine.
If you are replacing the bushings, make sure you research carefully online. There is a sequence to inserting the bushings. Shaft first, then the bushing in to the control arm...but you have to make up a fixture so you are inserting the bushing by pressing on the outer shell of the bushing, not the shaft. If you use the shaft to insert the bushing you risk separating the rubber material from the shells. The bushing that I had that failed had only about 2K miles on it, when the car was restored they seemed to have damaged the bushing on the one side. The picture attached is what literally fell out of the LCA, that is not after any work by me to remove.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: LCA's worn out/junk? [Re: 83hurstguy] #2753405
03/19/20 10:47 AM
03/19/20 10:47 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The LCA bushings are easy to damage or destroy without some experience with them. If those involved aren't familiar with the slop being posted about, then they may not be familiar with the bushing install. Might be best to have someone more familiar with them review the bushings.
Where in Illinois are you? Anywhere near me? I'm in Benton 62812.
Master, again and still
Re: LCA's worn out/junk? [Re: DaveRS23] #2753425
03/19/20 11:48 AM
03/19/20 11:48 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Ya they are kinda loose there, the only upgrade is a set of bigblock lower arms as they have a sleeve belled out there and tend to be less worn. I have an nos bigblock arm and it is looser than my 40k mile originals so maybe a vendor thing. I have seen the nonbelled arms get pretty loose there, would think it could cause a phantom clunk under certain conditions. I change then to the better arms if I have them.
Re: LCA's worn out/junk? [Re: 83hurstguy] #2753426
03/19/20 11:49 AM
03/19/20 11:49 AM
IL
8
IL
Thanks everyone, appreciate the feedback. They were clearly put together wrong when restored a while ago, because the rubber bushings had failed by squeezing out like posted above (I didn't take any pictures of the "before" condition).
We replaced the rubber bushings with the firmfeel delrin bushings. They are one piece solid bushings, and they pressed into the lower arm using what I could consider to be reasonable effort.
We are in the south Chicago suburbs (Mokena, IL). We've done control arm bushings before on GM cars, so it's not my first rodeo with bushings, but my first experience with Mopar stuff.
Re: LCA's worn out/junk? [Re: 83hurstguy] #2753448
03/19/20 12:55 PM
03/19/20 12:55 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, that slop is normal, but it can be made tighter.
https://youtu.be/Nwes-SP8u4w
Re: LCA's worn out/junk? [Re: Jim_Lusk] #2753483
03/19/20 02:33 PM
03/19/20 02:33 PM
IL
8
IL
Thanks Jim! Ironically I had found your video a bit ago, thanks for sharing (and for putting that together!)
Re: LCA's worn out/junk? [Re: 83hurstguy] #2753542
03/19/20 04:50 PM
03/19/20 04:50 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I'm also using the Firm Feel Delrin LCA bushings.. still to hit the road and track (road race track)... this summer!
Re: LCA's worn out/junk? [Re: Jim_Lusk] #2753638
03/19/20 09:08 PM
03/19/20 09:08 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good stuff. Thanks for sharing that. up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: LCA's worn out/junk? [Re: 4406bbl] #2754396
03/22/20 02:49 AM
03/22/20 02:49 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I think that you are ill informed. There were no "big block" suspension parts other than larger torsion bars.
Re: LCA's worn out/junk? [Re: Jjs72D] #2754905
03/23/20 09:34 AM
03/23/20 09:34 AM
IL
8
IL
Quick update for closure - we put the tension on the torsion bars and the slop was taken up.
Ironically, without tension on the torsion bars, the torsion bar sleeve didn't have the side-to-side slop that you could fix by cutting the arm apart and re-welding (shown in the video above), it's only radially around the torsion bar sleeve. I'm guessing if you hit a good bump it could cause the arm to migrate a bit, probably something to fix long-term.
Thanks again to everyone for the help.
