you guys running a pro tree transbrake,,,
#2753258
03/18/20 07:55 PM
03/18/20 07:55 PM
dartman366
Mt. Vernon, Ohio
have you wired up a switch to activate the reverse without having to keep your finger on the button (a real pain in tight pit spots) and if you have how did you do it? pics and diagrams welcome.
Re: you guys running a pro tree transbrake,,,
[Re: dartman366]
#2753259
03/18/20 08:01 PM
03/18/20 08:01 PM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Nope. Just shifter in reverse, push the button, back up. I'm a KISS kind of person. No switches and crap that aren't needed.
Button on the right side of the wheel. Never found it to be a problem. Had to turn the wheel, then push the button on occasion.
[Re: rickraw]
#2753283
03/18/20 09:19 PM
03/18/20 09:19 PM
Posts: 1,030 ohio
67mprfan
ohio
I had 2 buttons 1 on the wheel and a hand hailed 1
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: dartman366]
#2753313
03/18/20 10:38 PM
03/18/20 10:38 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2753525
03/19/20 04:16 PM
03/19/20 04:16 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
I have 2 buttons on steering wheel one with delay, one without, set delay box for 9999, gives me time to back up
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: dartman366]
#2753592
03/19/20 06:50 PM
03/19/20 06:50 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
The Turbo Action Pro brake doesn't require it be engaged for reverse to function. I know a lot don't like the TA brake, but it works OK for me.
[Re: an8sec70cuda]
#2753625
03/19/20 08:13 PM
03/19/20 08:13 PM
dartman366
Mt. Vernon, Ohio
I ran the TA brakes for years and had real good luck with them, but I upgraded to a CRT pro brake when i switched over to the BB and 727 set up and the button is just a pain in tight spots and close quarters when you have to manuver in reverse and be able to see where you are going, i'm just not as limber as I once was.
[Re: Cab_Burge]
#2753698
03/20/20 05:12 AM
03/20/20 05:12 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
My car came with a toggle switch mounted down low on the passenger side of the metal shifter box and the race one mounted into the steering wheel. Using the toggle switch to back up is way easier than trying to use the button on the steering wheel I am with Cab , i mounted a toggle switch on side of shifter cover . Brake button is mounted off dash beside tacho Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2753726
03/20/20 09:06 AM
03/20/20 09:06 AM
Posts: 9,871 MI, usa
dvw
MI, usa
Use the 3 pin neutral/reverse switch located on the case. T splice a wire to the hot side of the trans brake switch. T splice a wire to the feed side of the trans brake switch. Connect these 2 new wires to the outer 2 terminals of the factory 3 pin N/R switch. Now when you put the trans in reverse it will apply the trans brake. For safety I would add a toggle switch in line in the new Hot feed wire. That way you can turn this feature off when going down track. Doug
[Re: CRT]
#2754252
03/21/20 04:26 PM
03/21/20 04:26 PM
dartman366
Mt. Vernon, Ohio
Thanks guys, i should be able to handle that task
[Re: dartman366]
#2754302
03/21/20 07:53 PM
03/21/20 07:53 PM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
I ended up not using my T-brake valve body but I had planned to use the reverse lights. It was quite the adventure to find that wiring in my car, until i remembered it had a console originally(I also wanted my back up lights to work again).
68 Barracuda Formula S 340
