you guys running a pro tree transbrake,,, #2753258
03/18/20 07:55 PM
03/18/20 07:55 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
have you wired up a switch to activate the reverse without having to keep your finger on the button (a real pain in tight pit spots) and if you have how did you do it? pics and diagrams welcome.
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2753259
03/18/20 08:01 PM
03/18/20 08:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nope. Just shifter in reverse, push the button, back up. I'm a KISS kind of person. No switches and crap that aren't needed.
Button on the right side of the wheel. Never found it to be a problem. Had to turn the wheel, then push the button on occasion.
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2753279
03/18/20 09:15 PM
03/18/20 09:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I wired mine to the neutral safety switch. Works fine, don't have a diagram, I believe I tied into the reverse light wire.
Re: you guys running a pro tree transbrake,,, [Re: rickraw] #2753283
03/18/20 09:19 PM
03/18/20 09:19 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I had 2 buttons 1 on the wheel and a hand hailed 1
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2753313
03/18/20 10:38 PM
03/18/20 10:38 PM
My car came with a toggle switch mounted down low on the passenger side of the metal shifter box and the race one mounted into the steering wheel. Using the toggle switch to back up is way easier than trying to use the button on the steering wheel up
I have hit that dang steering wheel button way to many times on the return road taking off my gloves, neck collar and loosening up the harness, it ain't good when I'm in low gear tsk realcrazy Can you say teeth marks in the steering wheel shock whistling
Re: you guys running a pro tree transbrake,,, [Re: Cab_Burge] #2753525
03/19/20 04:16 PM
03/19/20 04:16 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I have 2 buttons on steering wheel one with delay, one without, set delay box for 9999, gives me time to back up
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2753592
03/19/20 06:50 PM
03/19/20 06:50 PM
an8sec70cuda Offline
The Turbo Action Pro brake doesn't require it be engaged for reverse to function. I know a lot don't like the TA brake, but it works OK for me.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: you guys running a pro tree transbrake,,, [Re: an8sec70cuda] #2753625
03/19/20 08:13 PM
03/19/20 08:13 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I ran the TA brakes for years and had real good luck with them, but I upgraded to a CRT pro brake when i switched over to the BB and 727 set up and the button is just a pain in tight spots and close quarters when you have to manuver in reverse and be able to see where you are going, i'm just not as limber as I once was. whistling
Re: you guys running a pro tree transbrake,,, [Re: Cab_Burge] #2753698
03/20/20 05:12 AM
03/20/20 05:12 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I am with Cab , i mounted a toggle switch on side of shifter cover . Brake button is mounted off dash beside tacho
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: you guys running a pro tree transbrake,,, [Re: tex013] #2753726
03/20/20 09:06 AM
03/20/20 09:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Use the 3 pin neutral/reverse switch located on the case. T splice a wire to the hot side of the trans brake switch. T splice a wire to the feed side of the trans brake switch. Connect these 2 new wires to the outer 2 terminals of the factory 3 pin N/R switch. Now when you put the trans in reverse it will apply the trans brake. For safety I would add a toggle switch in line in the new Hot feed wire. That way you can turn this feature off when going down track.
Doug
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2754001
03/21/20 12:06 AM
03/21/20 12:06 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Hook up the brake to the reverse lights
Re: you guys running a pro tree transbrake,,, [Re: CRT] #2754252
03/21/20 04:26 PM
03/21/20 04:26 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Thanks guys, i should be able to handle that task up
Re: you guys running a pro tree transbrake,,, [Re: dartman366] #2754302
03/21/20 07:53 PM
03/21/20 07:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ended up not using my T-brake valve body but I had planned to use the reverse lights. It was quite the adventure to find that wiring in my car, until i remembered it had a console originally(I also wanted my back up lights to work again).
68 Barracuda Formula S 340
