Air grabber air cleaner #2752899
03/17/20 06:36 PM
03/17/20 06:36 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have always loved seeing a big orange oval air cleaner on top of a Mopar engine. I picked up a lid from Indy and I'm thinking about picking up a base. I know that the filters are expensive and that the K&N don't fit well.
This will go on my 72 Cuda which is basically a hot rod with a lift off 6 pack hood. Clearance won't be a problem.
The car is a 4 speed with a Victor intake so there is no problem with the kick down linkage hitting, perhaps just the throttle cable.
The question is should I look for one from a 440 or a 383?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Air grabber air cleaner [Re: cdstl] #2752900
03/17/20 06:41 PM
03/17/20 06:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I may be wrong but I though it had to do with what carb you have so you get the right size opening for the carb top.
Re: Air grabber air cleaner [Re: stumpy] #2752914
03/17/20 07:19 PM
03/17/20 07:19 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
The 383 sits higher than the 440 if I'm not mistaken. The question is for suggestions as to what will clear the best, or what have you guys done that works. It's not about the size of the hole that the 4 barrel will take. It's kind of looking like a 383 base would be the way to go.
https://nicksgarage.com/aircleaner.htm#pietins
Re: Air grabber air cleaner [Re: cdstl] #2752925
03/17/20 07:56 PM
03/17/20 07:56 PM
BDW Offline
BDW  Offline
I don’t think there’s very much difference between the 2, definitely does look good though.
Re: Air grabber air cleaner [Re: cdstl] #2752927
03/17/20 07:58 PM
03/17/20 07:58 PM
A727Tflite Online content
A727Tflite  Online Content
If you have a windshield wiper motor - it needs to be a three speed - the two speed sticks straight out while the three speed is on an angle.
Re: Air grabber air cleaner [Re: A727Tflite] #2752935
03/17/20 08:38 PM
03/17/20 08:38 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Crap, I entirely forgot about the wiper motor. I have a 2 speed.
Hasn't there been a thread where it showed that a 2 speed would still clear?
edit... A quick look shows that some guys put a spacer between the grabber base and the carb.
Re: Air grabber air cleaner [Re: cdstl] #2752937
03/17/20 08:42 PM
03/17/20 08:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A 2 speed wiper clears just fine on E bodies.
The carb openings are all the same size 1968 and newer 4bbl wedge engines. Small mouth AFB were all done except on street hemi.
A 440 base is lower to the engine.
Re: Air grabber air cleaner [Re: NANKET] #2752972
03/17/20 10:16 PM
03/17/20 10:16 PM
BDW Offline
BDW  Offline
I have 2-speed on my E-body, no issues.
Re: Air grabber air cleaner [Re: cdstl] #2752979
03/17/20 10:42 PM
03/17/20 10:42 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you are mistaken
its the other way around
a 440 is a rb or raised block engine = lower aircleaner throat
a 383 is a b engine
Re: Air grabber air cleaner [Re: flypaper] #2752992
03/18/20 12:05 AM
03/18/20 12:05 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
you are mistaken
a 383 is a b engine
Well, yes but I guess what I meant was the 383 base is physically taller than the 440 base.
