Leaf spring restoration.. #2752917
03/17/20 07:29 PM
03/17/20 07:29 PM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
Is it recommended, or not recommended to sand blast leaf springs.
I'll be taking them completely apart to do so...
Re: Leaf spring restoration.. [Re: Chally426] #2752958
03/17/20 09:40 PM
03/17/20 09:40 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
A piece of 6" pipe, capped and soak them in evaporust if they are to be finished in bare metal. If black painted or real rusty and pitted, then blast them. Depends what you want.
Re: Leaf spring restoration.. [Re: 4406bbl] #2753222
03/18/20 06:20 PM
03/18/20 06:20 PM
Columbus, Ohio
Columbus, Ohio
I was wondering if sand blasting them would hurt the spring rate at all
Re: Leaf spring restoration.. [Re: Chally426] #2753260
03/18/20 08:01 PM
03/18/20 08:01 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
wont hurt the spring rate. have your blaster blast with a fine media. anything numerically below 50 grit is rock, 50-100 glass is a great media for leafs. i blast probably 15 sets a month and no issues.
Re: Leaf spring restoration.. [Re: chrisf] #2753273
03/18/20 08:57 PM
03/18/20 08:57 PM
Columbus, Ohio
Columbus, Ohio
Awesome... Thanks
Re: Leaf spring restoration.. [Re: Chally426] #2753327
03/18/20 11:37 PM
03/18/20 11:37 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I used evap-o-rust for mine - they look fantastic
Re: Leaf spring restoration.. [Re: Morty426] #2753440
03/19/20 12:29 PM
03/19/20 12:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Always wondered if powder coating spring leafs at 375 degrees would harm them.
Re: Leaf spring restoration.. [Re: John_Kunkel] #2753708
03/20/20 08:02 AM
03/20/20 08:02 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I had the springs for 2 different cars acid dipped and powder coated with no ill effects
