1974 charger T bars
#2751034
03/11/20 03:34 PM
03/11/20 03:34 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
I have a 1974 charger SE came with 318 now has a big block . just looking for info. I used Schumacher mounts . is it 74 only or is it 62 to 74 B & E body like mopar performance book says,, correct with its a 41 inch bar ? I rebuilt the suspension completely its just seems very bouncy in the front . I even put polly isolaters in. I was just thinking a bigger bar stiffen it up a little. I have 96. in my 1969 charger . thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 1974 charger T bars
[Re: jcc]
#2751234
03/12/20 12:18 PM
03/12/20 12:18 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
I have a 1974 charger SE came with 318 now has a big block....I rebuilt the suspension completely its just seems very bouncy in the front. I even put poly isolaters in. IMO, anything in this era mopar needs at the min 1" TB...Shocks need to balanced to TB size From everything I've read, bigger is better in this department, within reason. And quality shocks are a must.
[Re: sparcy]
#2751277
03/12/20 02:02 PM
03/12/20 02:02 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Don't be afraid of larger diameter TBs.... every incremental step you make in size will be noticable... but I'd start at around 1.10 or 1.12... and consider slightly siffening up the leafs... as well as getting better shocks... double-adjustables bet bet for tuning your ride/comfort.
I've tried many different sizes... the small sizes (~1.00) are not even worth the time/expense. I love my 1.24 (largest that will fit through the hex of 1.25). Firm Feel has a wide selection and in the correct lengths per body.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2751342
03/12/20 04:49 PM
03/12/20 04:49 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
this is from the sway away website...
MOPAR Torsion Bars A, B & E Body – 1962-1976 Sway-A-Way’s high-performance torsion bars designed for MOPAR A,B, and E body vehicles. Engineered to provide a substantial increase in stiffness, Sway-A-Way’s MOPAR torsion bars will dramatically improve your vehicle’s handling by reducing body roll, dive, squat, and increasing your overall vehicle control. All torsion bars are clocked to allow for factory ride height within the adjustment range of the factory adjuster. Included with all Sway-A-Way MOPAR torsion bars are two polyurethane bushings and two circlip retaining rings. Whether you’re looking to stiffen up your daily driver, build a dedicated track car or anywhere in-between, Sway-A-Way offers sizes ranging from .96” to 1.24”, allowing you to source the correct bar for your application. Here is a chart showing relative spring rates of the different bar lengths and diameters. DODGE SPRING RATES
[Re: Sniper]
#2752840
03/17/20 01:59 PM
03/17/20 01:59 PM
Mopar Mitch
Good to see their choices in Mopar TBs... I wonder if they had previous involvement with California Suspension/Moparts (ahead of the times in the 1980s)?
Mopar Mitch
