1050 dominator question
#2752176
03/15/20 03:16 PM
03/15/20 03:16 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
Does anyone know or have the overall height measurements of a dominator from bottom of throttle plate to the air cleaner flange? I’m figuring out overall manifold,carb and air cleaner stack height for hood clearance, Thanks,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: 1050 dominator question
[Re: bigD]
#2752233
03/15/20 05:23 PM
03/15/20 05:23 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
[Re: bigD]
#2752322
03/15/20 08:23 PM
03/15/20 08:23 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
If it is a non HP 8082 J numbers are correct, I think I don't have one of those now, I have used them in the past and they where Identical looking to the 9375 non HP carbs I had back then The HP carbs are a tiny bit taller to the smooth tops, maybe not
