1050 dominator question #2752176
03/15/20 03:16 PM
03/15/20 03:16 PM
Hatfield,Pa.
bigD Offline OP
bigD  Offline OP
Hatfield,Pa.
Does anyone know or have the overall height measurements of a dominator from bottom of throttle plate to the air cleaner flange? I’m figuring out overall manifold,carb and air cleaner stack height for hood clearance, Thanks,D beer
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: 1050 dominator question [Re: bigD] #2752233
03/15/20 05:23 PM
03/15/20 05:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
3.5”
Re: 1050 dominator question [Re: bigD] #2752267
03/15/20 06:18 PM
03/15/20 06:18 PM
Which List # is it, some are a lot taller than others, List 6464 is a bunch taller than the List 9375 non HP carbs are shruggy
Re: 1050 dominator question [Re: Cab_Burge] #2752315
03/15/20 08:13 PM
03/15/20 08:13 PM
Hatfield,Pa.
bigD Offline OP
bigD  Offline OP
Hatfield,Pa.
List #8082 up
Re: 1050 dominator question [Re: bigD] #2752322
03/15/20 08:23 PM
03/15/20 08:23 PM
If it is a non HP 8082 J numbers are correct, I think up
I don't have one of those now, I have used them in the past and they where Identical looking to the 9375 non HP carbs I had back then up
The HP carbs are a tiny bit taller to the smooth tops, maybe not confused
