1978 440 Performance Upgrade ideas??? #2751403
03/12/20 09:09 PM
03/12/20 09:09 PM
Albuquerque, New Mexico
moparmatt Offline OP
I have had several 440's over the years but they were all late 60's early 70's chargers, Roadrunner's etc. Im now restoring my 78 Power wagon factory 440 truck atuo, A/C, CC, loaded cool truck! but I know that 440 is lacking on a bunch of stuff the early ones had! Any suggestions on performance upgrades? thanks
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2751423
03/12/20 10:21 PM
03/12/20 10:21 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Up the compression, easiest way is install a set of closed chambered heads (915 or 516). Edelbrock RPM intake, headers, 750 carb for starters.
Re: 1978 440 Performance Upgrade ideas??? [Re: GODSCOUNTRY340] #2751436
03/12/20 11:23 PM
03/12/20 11:23 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Depends on what you are trying to accomplish.
If you just want to wake it up a little without spending a bunch of money or giving up any stock manners, get a degree wheel and a new multi key timing chain set and advance the cam 4 degrees. Add a good dual exhaust system, make sure that Thermoquad is well tuned, recurve the distributor and it will impress you compared to what it was and probably gain a few MPG.
Kevin
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2751447
03/13/20 02:58 AM
03/13/20 02:58 AM
I would replace the heads with a set of aluminum 440 Source 80 CC heads or a similar set of another cheaper brand imports like Speedway or Pro Comps. maybe even a set of Eddy 75.0 CC cheaper RPM heads scope
That will give you bigger intake and exhaust valves with a lot better set of ports so the motor will breathe better, add a good set of headers and or a 2.5 or 3.0 complete dual exhaust system with straight through muffs and let that truck rock and roll with more power and torque up twocents scope
add tuning the carb and degreeing and advancing the cam will really wake that truck motor up devil
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2751450
03/13/20 03:50 AM
03/13/20 03:50 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The bigger difftween earliers and later engines is the compression rate. Factory lowered down with lower pistons. The correct way to bump up would be then get the correct pistons.
Then you can choose the camshaft, HP exhaust manifolds, windage tray, valve springs. But need to bump up the compression rate.
The cheaper and cost efective for this is KeithBlack pistons. They have two for 440, one flat top, and one with quench step. On $400 rate
You can also get closed heads as mentioned, but that could be more expensive than the pistons ( $1000 rate ), althought easier to bump out the compression rate and to work. If you can build the engine by yourself, the pistons will be cheaper and still the correct way. Since 69 all engines where open chamber heads, so you can live with the heads you have. Maybe mill down a bit will help a bit more. Get metallic headgaskets.
After get the pistons, you still can get closed chamber heads depending on which pistons you get and how they fit into the block, block height, headgasket used etc... but pistons first.
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2751466
03/13/20 09:02 AM
03/13/20 09:02 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Those engines were designed for a very different purpose that you want it for.
If the engine has the stock pistons, closed chamber iron heads won't help much. Stock pistons are .080" or more down in the hole. And that means that there is no way to get any quench at all so detonation is very likely. I have worked with these engines quite a few times. In fact, I still have a couple in the barn.
Improvements certainly can be made, but they detonate like heck with stock pistons so it usually takes a lot of trial and error to see what they can put up with. Optimal timing is impossible to get.
Do you have a budget or level of difficulty in mind? The better flow with new aluminum heads would help and would work with any future improvements, so that would be the first thing I would do. Then cam, intake, carb, and headers. In other words, the only desirable parts on the engine are the block, rods, and crank. Even the oil pan should be changed for more capacity.
twocents
Master, again and still
Re: 1978 440 Performance Upgrade ideas??? [Re: DaveRS23] #2751472
03/13/20 09:39 AM
03/13/20 09:39 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
If the engine is getting rebuilt anyway, put in pistons with a little better compression ratio. This is key to getting the engine up to its potential.
If the heads need a lot done to them (guides, valves, etc) then replace them with an aluminum "replacement" head like the E-street head or the Stealth. Much cheaper in the long run to buy these then rebuild 40 year-old cast iron heads. You'll also benefit from lighter weight and a little better flow.
'63 Dodge 330
11.19 @ 121 mph
Re: 1978 440 Performance Upgrade ideas??? [Re: NachoRT74] #2751482
03/13/20 10:01 AM
03/13/20 10:01 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
KB got actually 3 pistons for 440 with stock stroke
KB184 which is pretty much stock CH with quench step.
KB236 which is flat top and 0.065" higher CH
KB237 which is quench step AND 0.055" higher CH
These are going on the cheap, casted but Hypereutectic on $400 rate... after these you can go Diamond, Ross etc... being forged on $600 rate
Re: 1978 440 Performance Upgrade ideas??? [Re: NachoRT74] #2751487
03/13/20 10:15 AM
03/13/20 10:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you dont want to rebuild the short block: Usd Eddy heads, Performer RPM, corresponding cam, headers. Even at low compression with the right cam this combo runs very good. I'd spend money on heads instead of short block every time.
Doug
Re: 1978 440 Performance Upgrade ideas??? [Re: dvw] #2751780
03/14/20 10:09 AM
03/14/20 10:09 AM
There was a dyno test on a low compression 440 that showed a 62 horsepower increase by adding 516 closed chambered heads. I can't remember where I found it but I wrote down their results. (pic)
Re: 1978 440 Performance Upgrade ideas??? [Re: DaveRS23] #2751785
03/14/20 10:18 AM
03/14/20 10:18 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
twocents
Detonation with pistons .080 in the hole?
Re: 1978 440 Performance Upgrade ideas??? [Re: GODSCOUNTRY340] #2751866
03/14/20 02:36 PM
03/14/20 02:36 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You forgot to note the most important part. The heads were ported. http://www.dodgecharger.com/forum/index.php?PHPSESSID=j2s0u5u3emvjtb9c9a33hc00s1&topic=104749.0
Re: 1978 440 Performance Upgrade ideas??? [Re: Pacnorthcuda] #2751981
03/14/20 07:50 PM
03/14/20 07:50 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
twocents
Yep, big time. And no amount of octane will calm it down. Timing has to be backed off so much that it starts running hot, which makes it worse. Real balancing act trying to get the timing where it won't ping bad. Most of those motor home big blocks of that era rarely made it past 60k.
Re: 1978 440 Performance Upgrade ideas??? [Re: DaveRS23] #2751993
03/14/20 08:38 PM
03/14/20 08:38 PM
twocents
My experience with low compression motor home 440’s is very different from yours. Ran a 73 in a 70 Cuda, complete with 213 heads, two different cams, intakes, carbs and exhausts, and detonation was never a problem.
Re: 1978 440 Performance Upgrade ideas??? [Re: Pacnorthcuda] #2752005
03/14/20 09:33 PM
03/14/20 09:33 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Would like some more? I have several in the barn, some with trannies. Virgin territory.
Re: 1978 440 Performance Upgrade ideas??? [Re: DaveRS23] #2752021
03/14/20 11:02 PM
03/14/20 11:02 PM
I've got a 75 440 with factory smog pistons with 516 closed chamber heads, run 87 octane and have never heard even a hint of pinging and it's in a 1954 (heavy) flat fender 1 ton Power Wagon. Too much compression and advanced timing causes pinging (pre ignition).
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2752022
03/14/20 11:16 PM
03/14/20 11:16 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Way back I did a dyno test on my 78 Ramcharger with stock 440, all it has for mods is dual exhaust, performer intake and edel 750 carb. It runs great, starts great even in -30c, doesn't burn a drop of oil, but put down a whopping 120-ish rwhp. The compression on these motors is down in the 7's.
A modern rotating assembly and decent heads is the only good way out.
Re: 1978 440 Performance Upgrade ideas??? [Re: Uberpube] #2752028
03/14/20 11:39 PM
03/14/20 11:39 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have a 78 440 out of a motorhome with 516 heads and I can't get it to ping, even at sea level, with 87 octane fuel.
Re: 1978 440 Performance Upgrade ideas??? [Re: elmor353] #2752037
03/15/20 02:58 AM
03/15/20 02:58 AM
I am pulling it and going to rebuild so it will be apart, so pistons for sure already have the eldebrock RPM and I also bought the matching edelbrock carb I really wanted to keep the thermoquad but there was this little "fire thing" that happened. The truck is a restoration with the exception of the intake and carb. Its a loaded truck A/C, CC, PS, PB, AMFM and everything still works too!
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2752083
03/15/20 10:37 AM
03/15/20 10:37 AM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Before you install that CarterBrock carb, consider the new Street Demon. Kind of an updated version of the Thermoquad. It is all I install now on stockish engines. It is the best out of the box carb for those applications that I have ever used.
The CarterBrocks aren't a bad carb, but their calibrations really need an update.
https://www.hotrod.com/articles/street-demon-750-carb-review/
