Hot rod power tour and a spool!
#2750454
03/09/20 01:05 PM
03/09/20 01:05 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all,
Well I am super excited to announce I am going to enjoy the hot rod power tour this year. My buddy and i are going to be taking my 69 big block dart on the trip. A couple of questions I was hoping to get advice on. First off should I get an electric fan for it? i mean it has a big aluminum rad and a shroud but can creep up heat wise in terrible traffic. The second question is I run a spool in it. My concern is how well is that going to hold up on a weeks worth of 150 plus miles? I guess I am wondering if I should change it out for limited slip. It is in a dana set up. Finally any tips or pointer would be great! I am a newbie at this! Mike
1969 Dodge Dart Swinger
Re: Hot rod power tour and a spool!
[Re: MikeyT]
#2750459
03/09/20 01:19 PM
03/09/20 01:19 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Leave the spool in there...you won't notice it until you try to parallel park, lol.
On the cooling...do you currently run a belt driven fan? If so, leave it on there and maybe add an electric pusher fan on the front of the radiator. I ran a similar setup for years and it worked great. If it starts to get warm in traffic, turn on the electric fan.
[Re: MikeyT]
#2750480
03/09/20 02:11 PM
03/09/20 02:11 PM
Posts: 19,948 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I used to drive my car to/from the track with a spool, about 50 miles each way, maybe a little further. No issues. I did learn to hate driving on the street with a spool, but that was just personal preference.
Earning every penny of that moderator paycheck.
DBAP
[Re: dOoC]
#2750861
03/10/20 11:17 PM
03/10/20 11:17 PM
Posts: 2,255 IL
furious70
IL
x2 on the you can get caught sitting in the heat, you need to be confident in your car staying cool stuck in traffic for 15-20min. You'll also be on a fair amount of sketchy roads and potential for all day rain. Think about how long the drive will take at 35mph nursing that spool in all day rain.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2750921
03/11/20 08:52 AM
03/11/20 08:52 AM
an8sec70cuda
The tires you have on the car will determine how the car acts on wet pavement, not the spool.
[Re: an8sec70cuda]
#2750965
03/11/20 11:37 AM
03/11/20 11:37 AM
Posts: 19,464 north of coder
moparx
how one can tolerate a spool also depends on the individual. just the same as a real lumpy cam. some will say no problem, while others will have the opposite opinion. i have no problem with either cam nor spool on the street, but your results can possibly be quite different ! just understand fully how a spool acts in all situations, know what your tolerance is, and act accordingly.
