'00 Dakota 5.9- no pulse to injectors...
#2749943
03/07/20 07:02 PM
03/07/20 07:02 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Finishing up the swap into the Dakota and went to fire it up to fill it with coolant. Ran for about a minute and died. Has spark at plug and good pressure at rail. It will start by pouring gas into throttle body. No codes. If my feeble mind is remembering correctly, isn't this a bad crank sensor? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: '00 Dakota 5.9- no pulse to injectors...
[Re: Jim_Lusk]
#2750037
03/08/20 08:17 AM
03/08/20 08:17 AM
I_bleed_MOPAR
Buford, GA
Thanks, Jim, appreciate the help. From what I can find online, I should have 12v at the injector w/ key on/start and the ground pulse coming from the PCM? If I have the 12v at the injectors, my problem then is the ground side? What triggers the PCM to ground the injectors? Online diagrams are hard to follow, at least to me. Never can seem to find a decent one. Tim
[Re: I_bleed_MOPAR]
#2750045
03/08/20 08:52 AM
03/08/20 08:52 AM
Guitar Jones
The distributor pickup plate. The Hall effect pickup under the plate specifically is what batch fires the injectors.
[Re: Guitar Jones]
#2750187
03/08/20 04:34 PM
03/08/20 04:34 PM
I_bleed_MOPAR
Buford, GA
Thanks, GJ. I have a spare so I'll give it a try. Tim
[Re: I_bleed_MOPAR]
#2750477
03/09/20 02:02 PM
03/09/20 02:02 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Do you have 12v with the key in Start 1 & Start 2 positions? Check all your grounds.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
