Rolling car help #2748549
03/03/20 12:17 PM
03/03/20 12:17 PM
W.Va
fowl play Offline OP
W.Va
Car is a 68 Dodge dart drag car. Stock front suspension.dana rear . Car has always been hard to roll or push.what to check to free up? Car has four wheel disc brakes. Small block auto. Just thinking before race season comes around.
Re: Rolling car help [Re: fowl play] #2748551
03/03/20 12:26 PM
03/03/20 12:26 PM
central il.
second 70 Offline
second 70  Offline
central il.
I would check the drag on the brakes. Race brakes usually back off so there is no drag but it scares the heck out of you to drive it normal because a light touch on the pedal doesn't do much. Also the wheel bearings to make sure the wheels spin freely.
Re: Rolling car help [Re: fowl play] #2748552
03/03/20 12:27 PM
03/03/20 12:27 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I also have a 68 dart with stock front and Dana rear. Big Block / 727. The car was impossible to roll with the trans in it. Once I removed that, the car rolled free. I am sure it is a non-rollerized set up in the trans. Is this common? Might be your problem as well.
Re: Rolling car help [Re: fowl play] #2748553
03/03/20 12:29 PM
03/03/20 12:29 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
...toe in,
...rebuild calipers
Re: Rolling car help [Re: BigBlockGTS] #2748554
03/03/20 12:31 PM
03/03/20 12:31 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Does the rear have a spool in it ?
Re: Rolling car help [Re: BigBlockGTS] #2748555
03/03/20 12:35 PM
03/03/20 12:35 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I can easily push my car in the staging lanes by myself with a non rollerized 727 in neutral.
With a spool, though, it is exceedingly difficult to go around corners!
'63 Dodge 330
11.19 @ 121 mph
Re: Rolling car help [Re: GY3] #2748557
03/03/20 12:47 PM
03/03/20 12:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check the driveshaft pinion angle.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Rolling car help [Re: pittsburghracer] #2748558
03/03/20 12:52 PM
03/03/20 12:52 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If the rear is an 8 3/4 with a spool check the housing for straightness. A slight bend and the car is very hard to push.
Re: Rolling car help [Re: fbs63] #2748559
03/03/20 12:58 PM
03/03/20 12:58 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
If the transmission and driveshaft are in the car, a galled transmission rear support makes a car hard to push
Re: Rolling car help [Re: fowl play] #2748563
03/03/20 01:08 PM
03/03/20 01:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do a process of elimination... pull the drive shaft first then try.. then pull the brake pads and try
wave
Re: Rolling car help [Re: fowl play] #2748581
03/03/20 01:39 PM
03/03/20 01:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
What master cylinder is in the car?
If it is a stock looking one with dual equal size reservoirs it may still have the residual valves in it, they hold 10lbs. pressure for stock drum brakes and that pressure will hold the pads against the rotors scope
You can back off one of the hard lines and if it has pressure on it and drips out that is the problem wrench scope
You can remove them by using a #8 self tapping screw in the brass flare that is press into the master cylinder to hold the tiny residual valves wit the springs on the ends, remove them and reinstall the flares and tighten them up hard enough to make them flare out again so they stay in place so they sealed up against the M.C. upwrench scope
Re: Rolling car help [Re: fowl play] #2748604
03/03/20 02:43 PM
03/03/20 02:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Who's disc brakes? Wilwood???
Re: Rolling car help [Re: MR_P_BODY] #2748617
03/03/20 03:10 PM
03/03/20 03:10 PM
AndyF Offline
AndyF  Offline
wave
Exactly. There are only a few things it can be so start with the obvious and move to the more difficult. Tire pressure is the first thing to check, toe in can be checked. pulling the driveshaft is the next step. Put the car in the air and pull the wheels and spin the rotors by hand. Shouldn't take more than an hour or two in the shop to figure it out.
Re: Rolling car help [Re: AndyF] #2748645
03/03/20 04:16 PM
03/03/20 04:16 PM
W.Va
W.Va
Will start with driveshaft out. Car has aerospace brake and they back off. Just looking for a little something. Thanks everyone
Re: Rolling car help [Re: fowl play] #2748705
03/03/20 07:01 PM
03/03/20 07:01 PM
HR3128 Offline
HR3128  Offline
The last car I had was hard to push. What I found to be the problem was the steering rack. There was a plastic bushing on the passenger side of the rack that held the rack gear. It had broken & allowed the passenger side front wheel to flop around. I made a replacement bushing from aluminum.
Re: Rolling car help [Re: HR3128] #2748714
03/03/20 07:20 PM
03/03/20 07:20 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Let me state the obvious. Is the car square? Not Dog tracking? Way back in the 70''s at a Mopar seminar they talked about the same thing. Next thing would be the weak 8 3/4 housing.
Real Men shift for themselves
Re: Rolling car help [Re: fowl play] #2748739
03/03/20 08:40 PM
03/03/20 08:40 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Spool ? ... like has been said - that can be a bummer !
If the tires are not matched perfectly it can be a PITA !
And it’s a double PITA on turns ... even if they match
Re: Rolling car help [Re: dOrk !] #2748758
03/03/20 09:33 PM
03/03/20 09:33 PM
W.Va
W.Va
Yes has a spool Dana 60. Tires are within 1/4 probably.
Re: Rolling car help [Re: fowl play] #2748773
03/03/20 10:35 PM
03/03/20 10:35 PM
okla.
sam64 Offline
sam64  Offline
okla.
I worked on a car that someone put a spring on the brake pedal pulling towards the master cylinder for some odd reason. Pulled spring off and 1 person could push the car that was difficult with 2 people prior.it wasn't a real stout spring but it held the brakes.
Re: Rolling car help [Re: sam64] #2748786
03/03/20 10:58 PM
03/03/20 10:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine wouldn't even roll down the hill in the staging lanes at Dragway 42. Loosened upped the Will wood brakes. Rolls easy. Made ZERO difference in ET. I've had the front Will woods apart numerous times. The strange part is only the front pair stick. Never the rears.
Doug
