Re: Rolling car help
[Re: fowl play]
#2748551
03/03/20 12:26 PM
03/03/20 12:26 PM
Posts: 1,696 central il.
second 70
central il.
I would check the drag on the brakes. Race brakes usually back off so there is no drag but it scares the heck out of you to drive it normal because a light touch on the pedal doesn't do much. Also the wheel bearings to make sure the wheels spin freely.
[Re: BigBlockGTS]
#2748555
03/03/20 12:35 PM
03/03/20 12:35 PM
Posts: 4,663 Wichita
GY3
Wichita
I also have a 68 dart with stock front and Dana rear. Big Block / 727. The car was impossible to roll with the trans in it. Once I removed that, the car rolled free. I am sure it is a non-rollerized set up in the trans. Is this common? Might be your problem as well. I can easily push my car in the staging lanes by myself with a non rollerized 727 in neutral. With a spool, though, it is exceedingly difficult to go around corners!
[Re: GY3]
#2748557
03/03/20 12:47 PM
03/03/20 12:47 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check the driveshaft pinion angle.
[Re: fowl play]
#2748604
03/03/20 02:43 PM
03/03/20 02:43 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Who's disc brakes? Wilwood???
[Re: AndyF]
#2748645
03/03/20 04:16 PM
03/03/20 04:16 PM
Posts: 69 W.Va
fowl play
W.Va
Will start with driveshaft out. Car has aerospace brake and they back off. Just looking for a little something. Thanks everyone
[Re: HR3128]
#2748714
03/03/20 07:20 PM
03/03/20 07:20 PM
Posts: 604 TN
1DGEMAN
TN
Let me state the obvious. Is the car square? Not Dog tracking? Way back in the 70''s at a Mopar seminar they talked about the same thing. Next thing would be the weak 8 3/4 housing.
Real Men shift for themselves
