Leaking Power Steering Gear 73 W100 #2739577
02/04/20 10:34 AM
02/04/20 10:34 AM
Cleveland, Ohio
northcoastmopar Offline OP
Cleveland, Ohio
The power steering gear on my 73 Power Wagon is leaking like crazy through pitman arm output shaft.
I see that pitman shaft seals are available. Should I go this route or look at getting a rebuilt steering gear?
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2739587
02/04/20 10:54 AM
02/04/20 10:54 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
That's your call. I would try seals first if it were me.
Re: Leaking Power Steering Gear 73 W100 [Re: NITROUSN] #2740634
02/07/20 11:45 AM
02/07/20 11:45 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Pitman shaft seals are pretty easy to install. I would go with that first. Napa should have them. I may have a mopar one somewhere around here.
Re: Leaking Power Steering Gear 73 W100 [Re: mopars4ever] #2745584
02/22/20 07:39 PM
02/22/20 07:39 PM
Cleveland, Ohio
Cleveland, Ohio
Ok I pulled the gear and bought a rebuild kit.
However when I pulled out the pitman shaft I’m not sure it’s going to be worth buttoning back up. The shaft is worn and has ridges on it. I’m thinking this is not going to seal?
Are these shafts available out there or should I just use the gear as a core and get a rebuilt one?
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2745590
02/22/20 07:59 PM
02/22/20 07:59 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
slap it back together, call napa on monday, order rebuilt gear under farm acct number 31999. done.
Re: Leaking Power Steering Gear 73 W100 [Re: rbkt65] #2745616
02/22/20 09:37 PM
02/22/20 09:37 PM
Cleveland, Ohio
Cleveland, Ohio
What’s farm account 31999?
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2745640
02/22/20 10:46 PM
02/22/20 10:46 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
it is an acct napa uses to give disccounts. most of time it is big discount. example: filter sale-napa filters are wix filters. on 31999, the filter will be approx 1/2 price. call a napa store tomorrow and ask for price on steering box with/without 31999.
Re: Leaking Power Steering Gear 73 W100 [Re: rbkt65] #2745808
02/23/20 04:55 PM
02/23/20 04:55 PM
Alberta
440_Offroader Offline
Alberta
Could you put a speedi sleeve on it? You might need to use something to push it on that far, but if you already bought a rebuild kit, it might be an option.
Re: Leaking Power Steering Gear 73 W100 [Re: 440_Offroader] #2745884
02/23/20 09:31 PM
02/23/20 09:31 PM
Cleveland, Ohio
Cleveland, Ohio
I don’t think any of the sleeves are wide enough. The shaft is 1.250 but the width for the two seals is roughly .625. The widest sleeve I can find is .313.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2747778
02/29/20 03:59 PM
02/29/20 03:59 PM
Cleveland, Ohio
Cleveland, Ohio
Ok.... got a remanufactured power steering gear from NAPA, got it installed and it’s reverse rotation to what I need. I ordered the one that NAPA shows for it (pic attached) but obviously something is wrong. Grrrrr.....they are closed now. Will have to wait until Monday.
Also...the current price is $20 less than I paid.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2747787
02/29/20 04:25 PM
02/29/20 04:25 PM
Cleveland, Ohio
Cleveland, Ohio
Looking at NAPA’s website again they show the same part number for D100 and W100.....grrr again, obviously not the case I should have checked myself.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2747887
02/29/20 10:24 PM
02/29/20 10:24 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
part number you want is ps 391038. 4x4 w/std rotation. did you ask for farm acct 31999?
Re: Leaking Power Steering Gear 73 W100 [Re: rbkt65] #2748246
03/02/20 10:09 AM
03/02/20 10:09 AM
Cleveland, Ohio
Cleveland, Ohio
Thanks!
I'll call this morning and check on that number.
They didn't know anything about that farm acct discount. They typed it in and nothing came in.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2748263
03/02/20 11:24 AM
03/02/20 11:24 AM
Cleveland, Ohio
Cleveland, Ohio
NAPA doesn't show availability on PS391038.
Rockauto shows an AC Delco reverse rotation but it's unavailable.
I have the core back and it's certainly reverse rotation, unfortunately I'm not showing any suppliers that show stock.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2748284
03/02/20 12:28 PM
03/02/20 12:28 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
was your first one just boxed wrong? the 88278052 shows std rotation. my local napa shows one in ft wayne ind. your are correct that avail of the number i gave you is none. it superscedes to new.
Re: Leaking Power Steering Gear 73 W100 [Re: rbkt65] #2748315
03/02/20 02:16 PM
03/02/20 02:16 PM
Cleveland, Ohio
Cleveland, Ohio
I need reverse rotation for the 4WD. I confirmed the rotation is indeed reversed on the original gear, turn the input shaft clockwise and pitman shaft turns counterclockwise.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2748349
03/02/20 04:30 PM
03/02/20 04:30 PM
N
N
Rock Auto shows a rebuild service of your gear box available.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2748375
03/02/20 06:01 PM
03/02/20 06:01 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
How about Steer and Gear in Columbus? Never dealt with them myself.
https://www.steerandgear.com/?gclid=EAIaIQobChMI8_Di_OT85wIVdB6tBh2m9wO6EAAYASAAEgIk9vD_BwE
1981 Dodge D150 360 auto
Re: Leaking Power Steering Gear 73 W100 [Re: basketcase] #2748654
03/03/20 04:56 PM
03/03/20 04:56 PM
Cleveland, Ohio
Cleveland, Ohio
Thanks all. Car-Id shows stock on the reverse rotation at a pretty good price. Ordered one...we'll see if it shows and it's correct. They are scarce out there.
Re: Leaking Power Steering Gear 73 W100 [Re: northcoastmopar] #2750364
03/09/20 09:13 AM
03/09/20 09:13 AM
Cleveland, Ohio
Cleveland, Ohio
On national backorder until the middle of April......
