removing paint from aluminum interior #2747938
03/01/20 04:03 AM
03/01/20 04:03 AM
st.louis,mo.
dart games Offline OP
st.louis,mo.
some bone head painted the aluminum interior of a car i have,whats a good product to use,that wont make a mess,and i wont have to take out every panel or make new panels
Re: removing paint from aluminum interior [Re: dart games] #2747960
03/01/20 10:30 AM
03/01/20 10:30 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have to ask what the product is......no way it won't make a mess!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: removing paint from aluminum interior [Re: hemi-itis] #2747980
03/01/20 11:33 AM
03/01/20 11:33 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
WD40 soaking and it will make a mess, and would be better if the panels were removed.....I use it to remove over spray....It works without attacking the aluminum like paint stripper does.
Re: removing paint from aluminum interior [Re: dart games] #2747989
03/01/20 11:58 AM
03/01/20 11:58 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I don't know whats bone head about painting it. Its way easier to clean than if left natural. I'd clean it up and either respray or if powder coating is preferred then remove and have the powder coating company strip and cost. Where I live powder coating isn't too crazy expensive. Had both my kirkey seats done for $60
Ok
Re: removing paint from aluminum interior [Re: cudatom] #2748062
03/01/20 04:44 PM
03/01/20 04:44 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Maybe a heat gun but that's a lot of work.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: removing paint from aluminum interior [Re: dart games] #2748112
03/01/20 07:33 PM
03/01/20 07:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Airplane shops use Aircraft stripper, it is messy but it doesn't hurt the aluminum either up
I have a gallon in the shop made by Kleen Strip, I bought it at Wal mart scope
Follow the directions on the can and buy cheap throw away brushes to put in on and some plastic body putty spreaders to remove the stripper, along with plenty of rags and follow up what the instruction say on clean up wrench up
Make sure and use good gloves, that stripper was not nice to my skin realcrazy tsk
Re: removing paint from aluminum interior [Re: Cab_Burge] #2748142
03/01/20 08:56 PM
03/01/20 08:56 PM
st.louis,mo.
st.louis,mo.
savoy,heat gun is a ideal,ive tried a butain torch to a piece i took of it does work,if anything else ill painted a different color,something i like
Re: removing paint from aluminum interior [Re: dart games] #2748148
03/01/20 09:35 PM
03/01/20 09:35 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
what's underneath the paint may scare (disappoint) you...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: removing paint from aluminum interior [Re: W.I.N. Racing] #2748383
03/02/20 06:57 PM
03/02/20 06:57 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I'd definitely go with a good dewaxer wash and scuff with 220. For the tight areas, try the green scotchbrite. An epoxy primer over that and a good quality engine enamel or a hammertone(like rustoleum) so you can roll and brush it.. Simple,fast with good results.
Re: removing paint from aluminum interior [Re: A/MP] #2748391
03/02/20 07:11 PM
03/02/20 07:11 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
soda blast
Re: removing paint from aluminum interior [Re: chrisf] #2748530
03/03/20 11:06 AM
03/03/20 11:06 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Some aluminum ..has a protective film of blue, stick on material .. not sure if thats the case here but, looks kinda like it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: removing paint from aluminum interior [Re: bigdad] #2748567
03/03/20 01:19 PM
03/03/20 01:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Back when I detailed cars a guy was using solvent to take tree sap off a hood and he got distracted by a phone call and left the rag sitting on the hood. When he came back after the phone call was over and picked the rag up all the paint under the rag was gone.
Re: removing paint from aluminum interior [Re: bigdad] #2748570
03/03/20 01:20 PM
03/03/20 01:20 PM
st.louis,mo.
st.louis,mo.
bigdad,this car has been a race car for 44 years,its a body in white car,beleave me its not protective coating,its paint
