Re: Hellcat crate in old iron performance?
[Re: Dragula]
#2746003
02/24/20 09:33 AM
02/24/20 09:33 AM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Just had mine out again yesterday doing some shock/suspension tuning and it went 5.81 in the 1/8th and 9.19 in the 1/4. 64 dodge 440, hellcat engine, 727 trans, dana 60 rear https://youtu.be/9HNYq-t3-Vw
[Re: RonP]
#2746068
02/24/20 12:29 PM
02/24/20 12:29 PM
Posts: 4,693 Wichita
GY3
Wichita
Just had mine out again yesterday doing some shock/suspension tuning and it went 5.81 in the 1/8th and 9.19 in the 1/4. 64 dodge 440, hellcat engine, 727 trans, dana 60 rear https://youtu.be/9HNYq-t3-Vw Very nice! What mods done to the engine?
[Re: 70VcodeCoronetRT]
#2746075
02/24/20 12:54 PM
02/24/20 12:54 PM
RonP
Jacksonville, NC
RonP, thats bad ass!!!! Tell us more about your combo? Gear? Convertor? weight? Engine mods? Thanks again Thanks, it is a blast. Hellcat takeout engine: Lower 10% ATI Upper hellraiser 2.72 pulley ID1050X injectors The rest of engine is 100% stock Using hellcrate PCM kit. I tune with HpTuners Cope 727 with T-Brake A reworked PTC converter that was originally way too loose and they didn't want to work with me on tightening it up. Atlantic coast converter changed it up some, but its still needs tightened a little more down track. They are building me a new one now. Leave off brake at 2400, flashes to 5,000 or so. Shift 6500-6600 Dana 60, ladder bars with 3.73 gear.
[Re: 70gtx1]
#2747706
02/29/20 11:56 AM
02/29/20 11:56 AM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
So is it safe to assume an out of the crate Hellcate engine with Mopar ECM in a 3800lbs e body could get in the high to mid tens?
#2747767
02/29/20 03:23 PM
02/29/20 03:23 PM
Posts: 2,256 IL
furious70
IL
Wallace says
Your ET / MPH computed from your vehicle weight of 3800 pounds and HP of 707 is 10.20 seconds and MPH of 132.45 MPH.
70 Sport Fury 68 Charger 69 Coronet 72 RR
#2747836
02/29/20 07:25 PM
02/29/20 07:25 PM
RonP
Jacksonville, NC
So is it safe to assume an out of the crate Hellcate engine with Mopar ECM in a 3800lbs e body could get in the high to mid tens? I ran the car before the upper pulley with only the lower which added a little less than 3lbs of boost and the car ran 10.00
[Re: dOOc]
#2748075
03/01/20 05:24 PM
03/01/20 05:24 PM
RonP
Jacksonville, NC
How big of a task were the electronics? I used the Mopar crate kit....It was really simple and the car started the very first time I tried it.
[Re: RonP]
#2748084
03/01/20 06:18 PM
03/01/20 06:18 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
How big of a task were the electronics? I used the Mopar crate kit....It was really simple and the car started the very first time I tried it. Is that KIT available separately... to adapt a motor out of a wreck ?
[Re: dOOc]
#2748126
03/01/20 07:59 PM
03/01/20 07:59 PM
RonP
Jacksonville, NC
How big of a task were the electronics? I used the Mopar crate kit....It was really simple and the car started the very first time I tried it. Is that KIT available separately... to adapt a motor out of a wreck ? yeah it is, mine came out of a wreck.
