Hellcat crate in old iron performance? #2745163
02/21/20 11:16 AM
02/21/20 11:16 AM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Just curious if anyone has had/seen old iron with a Hellcat engine run at the track? Just curious what the real world performance is in this swap? Thanks
Re: Hellcat crate in old iron performance? [Re: 70VcodeCoronetRT] #2745886
02/23/20 09:34 PM
02/23/20 09:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Under 6 sec in the 1/8th.....and only two gears....
https://www.youtube.com/watch?v=PlQJJDqXhq0
Re: Hellcat crate in old iron performance? [Re: Dragula] #2746003
02/24/20 09:33 AM
02/24/20 09:33 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Just had mine out again yesterday doing some shock/suspension tuning and it went 5.81 in the 1/8th and 9.19 in the 1/4.
64 dodge 440, hellcat engine, 727 trans, dana 60 rear
https://youtu.be/9HNYq-t3-Vw
Re: Hellcat crate in old iron performance? [Re: RonP] #2746068
02/24/20 12:29 PM
02/24/20 12:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very nice! What mods done to the engine?
'63 Dodge 330
11.19 @ 121 mph
Re: Hellcat crate in old iron performance? [Re: GY3] #2746071
02/24/20 12:41 PM
02/24/20 12:41 PM
Nebraska
Nebraska
RonP, thats bad ass!!!! Tell us more about your combo? Gear? Convertor? weight? Engine mods? Thanks again
Re: Hellcat crate in old iron performance? [Re: 70VcodeCoronetRT] #2746075
02/24/20 12:54 PM
02/24/20 12:54 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Thanks, it is a blast.
Hellcat takeout engine:
Lower 10% ATI
Upper hellraiser 2.72 pulley
ID1050X injectors
The rest of engine is 100% stock
Using hellcrate PCM kit. I tune with HpTuners
Cope 727 with T-Brake
A reworked PTC converter that was originally way too loose and they didn't want to work with me on tightening it up. Atlantic coast converter changed it up some, but its still needs tightened a little more down track. They are building me a new one now.
Leave off brake at 2400, flashes to 5,000 or so. Shift 6500-6600
Dana 60, ladder bars with 3.73 gear.
Re: Hellcat crate in old iron performance? [Re: RonP] #2746572
02/25/20 11:42 PM
02/25/20 11:42 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
RonP, I have seen your car on Facebook and YouTube before. Your car is amazing! Seeing your car run pretty much finalized my decision to hellcat swap my GTX in the near future. Keep up the good work!
Re: Hellcat crate in old iron performance? [Re: 70gtx1] #2747706
02/29/20 11:56 AM
02/29/20 11:56 AM
Nebraska
Nebraska
So is it safe to assume an out of the crate Hellcate engine with Mopar ECM in a 3800lbs e body could get in the high to mid tens?
Re: Hellcat crate in old iron performance? [Re: 70VcodeCoronetRT] #2747767
02/29/20 03:23 PM
02/29/20 03:23 PM
IL
furious70 Offline
furious70  Offline
IL
Wallace says
Your ET / MPH computed from your vehicle weight of 3800 pounds and HP of 707 is 10.20 seconds and MPH of 132.45 MPH.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Hellcat crate in old iron performance? [Re: 70VcodeCoronetRT] #2747836
02/29/20 07:25 PM
02/29/20 07:25 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I ran the car before the upper pulley with only the lower which added a little less than 3lbs of boost and the car ran 10.00
Re: Hellcat crate in old iron performance? [Re: RonP] #2748063
03/01/20 04:45 PM
03/01/20 04:45 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
How big of a task were the electronics?
Re: Hellcat crate in old iron performance? [Re: dOrk !] #2748075
03/01/20 05:24 PM
03/01/20 05:24 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I used the Mopar crate kit....It was really simple and the car started the very first time I tried it.
Re: Hellcat crate in old iron performance? [Re: RonP] #2748084
03/01/20 06:18 PM
03/01/20 06:18 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Is that KIT available separately... to adapt a motor out of a wreck ?
Re: Hellcat crate in old iron performance? [Re: dOrk !] #2748126
03/01/20 07:59 PM
03/01/20 07:59 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
yeah it is, mine came out of a wreck.
Re: Hellcat crate in old iron performance? [Re: dOrk !] #2748275
03/02/20 11:52 AM
03/02/20 11:52 AM
Nebraska
Nebraska
I was always curious how a 3 speed auto like the 727 would work with the hellcat motor. I guess it works pretty good! smile
