1964 Dodge 440 VIN Location #2746777
02/26/20 04:55 PM
02/26/20 04:55 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Don't want to go into too much detail, but I've got an opportunity to pick up a 64 Dodge 440. Trouble is there is no title and I don't know where to find it on the chassis. The original drivetrain is long gone and the tag is not on the driver's door. Tried looking under the rear package tray, but didn't find it. I trust the backstory of the car that was provided, but don't want any headaches with trying to make the car road legal. Anywhere else it might be on the car? Thanks....
Re: 1964 Dodge 440 VIN Location [Re: MarkZ] #2746784
02/26/20 05:15 PM
02/26/20 05:15 PM
Casco, MI
Savoy1964 Online content
Savoy1964  Online Content
Casco, MI
radiator core drivers side between rad and core support and under trunk seal drivers side near rear that's where i found them on a 64 Plymouth. Transmission might also have vin i don't know.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 1964 Dodge 440 VIN Location [Re: MarkZ] #2746803
02/26/20 05:57 PM
02/26/20 05:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No VIN partial or otherwise on the bodies for 1968 & earlier.
You said door, but the VIN tag should be on the drivers side on the body in the front door opening.
Re: 1964 Dodge 440 VIN Location [Re: Alaskan_TA] #2746817
02/26/20 06:27 PM
02/26/20 06:27 PM
A727Tflite Offline
A727Tflite  Offline
Go to the SOS and get an inspection form then call your local law enforcement agency and have them inspect the car - show them the SO number locations.
I beleive the state will make a tag for you to attach to the car. It won’t be the typical tag but you will be able to get a title that will match this new tag.
Re: 1964 Dodge 440 VIN Location [Re: Alaskan_TA] #2746819
02/26/20 06:28 PM
02/26/20 06:28 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Wasn't the body stamped with the sales order numbers not the vin prior to 68?
Re: 1964 Dodge 440 VIN Location [Re: markz528] #2746835
02/26/20 07:16 PM
02/26/20 07:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes, but the only way to tie the SON to a VIN is with original documentation that shows both.
Re: 1964 Dodge 440 VIN Location [Re: Alaskan_TA] #2746853
02/26/20 08:09 PM
02/26/20 08:09 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Sounds like it'll take a little leg work. Something to chew on. Thanks guys!
Re: 1964 Dodge 440 VIN Location [Re: MarkZ] #2746858
02/26/20 08:19 PM
02/26/20 08:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
So, I take it there's no fender tag (left apron) or VIN tag (left front hinge pillar) ?
And no registration paperwork or title ?
Re: 1964 Dodge 440 VIN Location [Re: topside] #2746955
02/27/20 07:45 AM
02/27/20 07:45 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When researching my VIN on my 64 the authorities couldnt trace it. Their system only works with 17 digit VIN. 64 only has 10 didgits.
Doug
