Re: Correct color of exhaust manifold nuts and bolts.
[Re: Little Detroit]
#2745974
02/24/20 04:46 AM
02/24/20 04:46 AM
Posts: 1,754 Phila
PhillyRag
Phila
the correct color is bare metal !
That's not a color
[Re: GMP440]
#2746584
02/26/20 03:13 AM
02/26/20 03:13 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is correct finish of exhaust manifold fasteners for 1969 340, and is most likely correct for 1968 318. AFAIK the difference between 318 and 340 exhaust manifold fasteners is just the length of the long hex nuts? 6 hex bolts, 4 hex nuts, 6 studs, all phosphated. 2 long hex nuts and 6 conical washers, all bare metal. The thick conical washers were stamped from steel plate with mill scale on both sides, so the washers also have mill scale on the top and bottom faces with bare metal on the edges. Of course the final finish was engine paint. You can verify these finishes by researching AMKproducts.com catalog. They offer a 318 kit of all these fasteners, Part No. C-8062 on page 6 here
[Re: burdar]
#2746653
02/26/20 11:40 AM
02/26/20 11:40 AM
Posts: 19,355 north of coder
moparx
Found this picture online and saved it. that pic is interesting in a couple of ways other than showing the exhaust manifold and attaching bolts. the transmission holding fixture the way that fixture seems "mygivered" to the overhead hoist and the most important, it looks like the torque converter is already bolted to the back of the engine. how did they correctly line up the pump ears and shafts to ensure the converter fit properly ?
[Re: moparx]
#2746654
02/26/20 11:47 AM
02/26/20 11:47 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
Found this picture online and saved it. that pic is interesting in a couple of ways other than showing the exhaust manifold and attaching bolts. the transmission holding fixture the way that fixture seems "mygivered" to the overhead hoist and the most important, it looks like the torque converter is already bolted to the back of the engine. how did they correctly line up the pump ears and shafts to ensure the converter fit properly ? Very easy to line up. Put the tangs of the gear and the slots in the converter at 6 and 12 O’clock and they go together really nicely. And if you don’t think so TRY IT, don’t argue from you couch. LOL
[Re: burdar]
#2746671
02/26/20 12:27 PM
02/26/20 12:27 PM
moparx
Yes, the torque converters were on the engine before it was painted and will have engine color overspray. The tool they used to line up the pump lugs is hanging from the hoist. i completely MISSED that tool ! not arguing from "my couch" [ ], but the few times i have pulled an engine with the converter attached, i have damaged the seal on the transmission. does anyone make that tool so a "tool" like me would be able to attach a transmission like shown ? [sorry for the jack]
