wire crimpers #2745652
02/22/20 11:46 PM
02/22/20 11:46 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
im in the market for a pair,dont want real big buck ones that do everything except make coffee,just a pair that do a excellent job that are not real big bucks im ashamed to say my $1 globemaster ones are about worn out (remember that name?),your opinion is wanted
thanks in advance
my ladder of success is missing some rungs
Re: wire crimpers [Re: rhad] #2745674
02/23/20 06:51 AM
02/23/20 06:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I guess the first thing to know is what are you crimping?
Different crimpers for different terminals.
I have 5 or 6 pairs, all for different style terminals,
Re: wire crimpers [Re: Sniper] #2745686
02/23/20 09:50 AM
02/23/20 09:50 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I had tried to crimp with these for some speaker ends. Gave way after a while.
https://www.harborfreight.com/8-in-...tool-63307.html?_br_psugg_q=wire+crimper
Ended up buying these and seemed good for the price. Got it on sale and used a coupon.
https://www.harborfreight.com/ratcheting-crimping-tool-63708.html?_br_psugg_q=wire+crimper
I like this style for wire strippers.
https://www.harborfreight.com/7-inch-wire-stripper-with-cutter-98410.html?_br_psugg_q=wire+stripper
Re: wire crimpers [Re: MI_Custumz] #2745690
02/23/20 09:58 AM
02/23/20 09:58 AM
RWG75
RWG75
The best crimping tool is a soldering iron.
Hold the terminal with a pair of pliers, use a lighter to melt the plastic at the crimp end and remove it. Slip some heat shrink over the wire, solder the terminal on, use the heat shrink to replace the insulation melted off in step one. Your mileage may vary, some crimp connections stay tight, a good solder job never comes loose.
Re: wire crimpers [Re: Sniper] #2745709
02/23/20 11:03 AM
02/23/20 11:03 AM
moparx Offline
moparx  Offline
^^^^ this.
i have a bunch of different crimpers as well as several modified sets of pliers and a couple of hydraulic crimping tools used on really big gauge stuff like battery terminals and welding cables.
i also, at times, remove the insulation, crimp, solder, then use shrink tube.
beer
Re: wire crimpers [Re: rhad] #2745729
02/23/20 11:58 AM
02/23/20 11:58 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
STACONS
Re: wire crimpers [Re: SV_MOPARS] #2745771
02/23/20 02:32 PM
02/23/20 02:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm up to 5 different crimpers now, though one's a backup, for pretty much everything from battery cables to plug wires to 22 gauge...
I agree with removing those clunky plastic sleeves on connectors, but mostly use the uninsulated ones with shrink-tube.
Re: wire crimpers [Re: topside] #2745780
02/23/20 03:01 PM
02/23/20 03:01 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I broke my 30ish year old crimpers a couple months back. Did the new fangled stuff, broke them, and went back to old school, if you have a good squeeze there's no need for compound leverage on the smaller stuff.
https://www.amazon.com/Channellock-...ce=ps-sl-shoppingads-lpcontext&psc=1
Re: wire crimpers [Re: 65Fury440] #2745781
02/23/20 03:05 PM
02/23/20 03:05 PM
KY
65pacecar Offline
65pacecar  Offline
KY
iagree for all around use those are hard to beat. Have a pair for the garage and In the road kit.
Re: wire crimpers [Re: MI_Custumz] #2745866
02/23/20 08:35 PM
02/23/20 08:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a pair similar to these. For crimping ends on they are very hard to beat.
My only regret with them is that I didn't buy them BEFORE I rewired my race car. bawling
Re: wire crimpers [Re: slantzilla] #2745872
02/23/20 08:53 PM
02/23/20 08:53 PM
CA
crackedback Offline
crackedback  Offline
CA
Klein Tools 1005
Crimps 10-22 gauge terminals.
If you are doing open barrel/f type then you should get a type specific crimper.
Re: wire crimpers [Re: crackedback] #2745913
02/23/20 11:26 PM
02/23/20 11:26 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I recently got this from Amazon. It's got five sets of different crimpers. The set that does the factory style crimp is only so-so, in part because it is too wide. It also came with a relatively square set that is perfect for the aftermarket style connectors.
https://www.amazon.com/gp/product/B0195VXA10/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Re: wire crimpers [Re: Jim_Lusk] #2745925
02/24/20 12:08 AM
02/24/20 12:08 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i looked on youtube and seen titan crimpers,they do a double crimp,most likely what ill buy
Re: wire crimpers [Re: rhad] #2745955
02/24/20 01:33 AM
02/24/20 01:33 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've no fewer than 8 pr of various for various jobs. for most small electric stuff (car stuff) I use a MAC Tools TCT-10. It's something very similar to WGGE WG-015. The pair I own is 40+ yrs old and still do everything I throw at them. I believe I use the machine screw cutters more than any of the other fitments save for the wire cutter.
Re: wire crimpers [Re: rhad] #2745968
02/24/20 02:15 AM
02/24/20 02:15 AM
AndyF Offline
AndyF  Offline
thanks in advance
That is like asking which socket to buy? You need a different socket for each size of bolt and you'll need different crimpers for different connectors. Wetherpack, Metripack, Packard 50, etc. all require different crimpers. I think I have about 10 different crimpers now that I'm working on EFI systems. EFI uses a lot of Metripack and GT connectors but they also throw in some oddball OEM stuff that I've never seen before.
Re: wire crimpers [Re: AndyF] #2746088
02/24/20 02:04 PM
02/24/20 02:04 PM
hooziewhatsit Offline
I have a generic pair like this, which is really nice if you want to crimp to the insulation as well as the actual wire.
https://www.amazon.com/dp/B07VKCCN12/ref=vp_d_pb_TIER2_cmlr_lp_B0195VXA10_pd
