elec ignition intermittent no fire
#2745131
02/21/20 08:58 AM
02/21/20 08:58 AM
Posts: 80 tampa florida
1badrt
tampa florida
has any one had a issue where electronic ignition had no fire but wiggle ignition module connector and then fires up, several modules and even new harness, could it be possible dist issue.
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: elec ignition intermittent no fire
[Re: burdar]
#2745216
02/21/20 01:26 PM
02/21/20 01:26 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Make sure the ground is good. Also, you can slightly compress the female wiring connectors so the male end fits really tight. You could have a loose connection. I had to do this even on a new harness. Compress?
Abe Lincoln
[Re: dart4forte]
#2745223
02/21/20 01:56 PM
02/21/20 01:56 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Make sure the ground is good. Also, you can slightly compress the female wiring connectors so the male end fits really tight. You could have a loose connection. I had to do this even on a new harness. Compress? Squish it (the connectors) down so it isn't loose fitting, sliding on instead of having to push them on
[Re: 1badrt]
#2745272
02/21/20 05:37 PM
02/21/20 05:37 PM
RapidRobert
but wiggle ignition module connector and then fires up, Check any adjacent wires that are being jostled when you wiggle it for a potential loose connection. You replaced the ECU pentastar connector/pigtail?
[Re: tman]
#2745373
02/22/20 03:06 AM
02/22/20 03:06 AM
Posts: 1,757 Phila
PhillyRag
Phila
Just for sheets and grins, check for loose wire/terminal to ballast resistor. For me, car would start, then die while idling. Jiggled the wires to ballast and it was loose from inside the crimped spade. Yeap: ballast coil wires usually Nichrome (soild & very hard) & just crimped to softer brass wire terminals. Not an ideal electrical connection. Plus with the ceramic filler, really can't see condition. That's why spares are always needed.
[Re: dragon slayer]
#2745416
02/22/20 09:42 AM
02/22/20 09:42 AM
1badrt
tampa florida
yes it is an unusual issue, been playing with mopars most of my life and always add many ground wires throughout the car, i always thought they had to few, i have replaced terminals with copper and have tried many things. its funny how the issue shows up, thank you every one for your help.
[Re: 1badrt]
#2745540
02/22/20 05:20 PM
02/22/20 05:20 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
has any one had a issue where electronic ignition had no fire but wiggle ignition module connector and then fires up, several modules and even new harness, could it be possible dist issue. If you wiggle the rubber connector boot and the issue goes away it is not likely the distributor or ballast resistor. It is the connector. I would use a small set of visegrip needle nose pliers and slightly, just slightly crush the female bullet connectors inside the rubber boot. Then using a long brass bristle brush clean the female bullet connector contacts inside the plug and the pins on the ECM box. Smeer a small dollop of dielectric grease in the contacts and push it in place. You may need to use some force to get the female connector to push over the male ECM pins.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
