elec ignition intermittent no fire #2745131
02/21/20 08:58 AM
02/21/20 08:58 AM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
has any one had a issue where electronic ignition had no fire but wiggle ignition module connector and then fires up, several modules and even new harness, could it be possible dist issue.
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: elec ignition intermittent no fire [Re: 1badrt] #2745139
02/21/20 10:23 AM
02/21/20 10:23 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Make sure it's well grounded.
Re: elec ignition intermittent no fire [Re: GODSCOUNTRY340] #2745145
02/21/20 10:40 AM
02/21/20 10:40 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
iagree Make sure the ground is good. Also, you can slightly compress the female wiring connectors so the male end fits really tight. You could have a loose connection. I had to do this even on a new harness.
Re: elec ignition intermittent no fire [Re: burdar] #2745216
02/21/20 01:26 PM
02/21/20 01:26 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Compress?
Abe Lincoln
Re: elec ignition intermittent no fire [Re: dart4forte] #2745223
02/21/20 01:56 PM
02/21/20 01:56 PM
Compress?
Squish it (the connectors) down so it isn't loose fitting, sliding on instead of having to push them on scope
Re: elec ignition intermittent no fire [Re: Cab_Burge] #2745259
02/21/20 04:58 PM
02/21/20 04:58 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
It couldn't hurt to check the reluctor gap as long as you're in there. I've had a car where it was too wide, and I guess became wider when hot, so it wouldn't start easily when hot. I closed it to ~.008 and it started everytime then.
Re: elec ignition intermittent no fire [Re: 1badrt] #2745272
02/21/20 05:37 PM
02/21/20 05:37 PM
Quote
Check any adjacent wires that are being jostled when you wiggle it for a potential loose connection. You replaced the ECU pentastar connector/pigtail?
Re: elec ignition intermittent no fire [Re: RapidRobert] #2745310
02/21/20 08:53 PM
02/21/20 08:53 PM
WA
tman Offline
tman  Offline
WA
Just for sheets and grins, check for loose wire/terminal to ballast resistor. For me, car would start, then die while idling. Jiggled the wires to ballast and it was loose from inside the crimped spade.
Re: elec ignition intermittent no fire [Re: tman] #2745373
02/22/20 03:06 AM
02/22/20 03:06 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Yeap: ballast coil wires usually Nichrome (soild & very hard) & just crimped to softer brass wire terminals. Not an ideal electrical connection. Plus with the ceramic filler, really can't see condition. That's why spares are always needed.
Re: elec ignition intermittent no fire [Re: PhillyRag] #2745411
02/22/20 09:28 AM
02/22/20 09:28 AM
VA
dragon slayer Offline
VA
This can be a ton of things, but if just wiggling the connector at module and you have replaced modules and harness it doesn't make much sense to me. All new components can't be bad. So either it is coincidence or how your module is grounded as mentioned above.
Re: elec ignition intermittent no fire [Re: dragon slayer] #2745416
02/22/20 09:42 AM
02/22/20 09:42 AM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
yes it is an unusual issue, been playing with mopars most of my life and always add many ground wires throughout the car, i always thought they had to few, i have replaced terminals with copper and have tried many things. its funny how the issue shows up, thank you every one for your help.
Re: elec ignition intermittent no fire [Re: 1badrt] #2745441
02/22/20 11:27 AM
02/22/20 11:27 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Through the years I have replaced many distributor pick up units. They can be very erratic and tough to diagnose.
Re: elec ignition intermittent no fire [Re: 1badrt] #2745540
02/22/20 05:20 PM
02/22/20 05:20 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
If you wiggle the rubber connector boot and the issue goes away it is not likely the distributor or ballast resistor. It is the connector.
I would use a small set of visegrip needle nose pliers and slightly, just slightly crush the female bullet connectors inside the rubber boot.
Then using a long brass bristle brush clean the female bullet connector contacts inside the plug and the pins on the ECM box.
Smeer a small dollop of dielectric grease in the contacts and push it in place. You may need to use some force to get the female connector to push over the male ECM pins.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
