74 duster 4 speed hump location?
#2744966
02/20/20 03:30 PM
02/20/20 03:30 PM
Posts: 5,669 South Dakota
hotairballoonpilot
South Dakota
Wondering on if anyone has the exact location for a 4 speed hump on a 74 duster? The car I am doing for a customer is an original 4 speed car. It is getting the complete floor pan installed but unfortunately the original pan was so rusted that I was not able to get a good location of the hump. The new AMD floor naturally doesn't come with the hole and has to be cut in. Not having one here to measure isn't an option. Just naturally don't want to have it in the wrong spot. Car is currently on a rotisserie and braced up.
thanks
corey
Contact Me about AMD Prices
Re: 74 duster 4 speed hump location?
[Re: moparmarks]
#2744972
02/20/20 03:44 PM
02/20/20 03:44 PM
hotairballoonpilot
South Dakota
I should also add I do have the original hump as tat naturally was not rusted but just more or less hanging in there. I was planning when I set the floor in the car that hoping it would more or less tell me where it went by the way things are shaped but thought I should do some CYA too.
thanks the pic does help some too!
[Re: hotairballoonpilot]
#2745082
02/20/20 11:25 PM
02/20/20 11:25 PM
Posts: 8,501 Candler,NC / Myrtle Beach, SC
JDMopar
I think you will find that when you lay the 4 spd hump onto the new floor pan, it won't fit but in one place. Trace around it with a sharpie, and step in enough for good overlap and cut the hole. I will be adding one to my 70 Duster that was a 3 on the tree, and that is my plan. I'm seriously thing of using Fusor panel bond to hold it, and then just weld up the screw holes needed to hold it down during the bonding process.
[Re: topside]
#2745274
02/21/20 05:58 PM
02/21/20 05:58 PM
hotairballoonpilot
South Dakota
thanks guys! I will plug away. In the process of getting the rear frame rail back up in place then onto the interior floor pan area.
corey
