74 duster 4 speed hump location? #2744966
02/20/20 03:30 PM
02/20/20 03:30 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Wondering on if anyone has the exact location for a 4 speed hump on a 74 duster? The car I am doing for a customer is an original 4 speed car. It is getting the complete floor pan installed but unfortunately the original pan was so rusted that I was not able to get a good location of the hump. The new AMD floor naturally doesn't come with the hole and has to be cut in. Not having one here to measure isn't an option. Just naturally don't want to have it in the wrong spot. Car is currently on a rotisserie and braced up.
thanks
corey
Contact Me about AMD Prices
Re: 74 duster 4 speed hump location? [Re: hotairballoonpilot] #2744968
02/20/20 03:40 PM
02/20/20 03:40 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Don't have measurements cuz the carpet is in but is a pic of my 72.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D200, 98 DAKOTA, .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 74 duster 4 speed hump location? [Re: moparmarks] #2744972
02/20/20 03:44 PM
02/20/20 03:44 PM
South Dakota
South Dakota
I should also add I do have the original hump as tat naturally was not rusted but just more or less hanging in there. I was planning when I set the floor in the car that hoping it would more or less tell me where it went by the way things are shaped but thought I should do some CYA too.
thanks the pic does help some too!
Re: 74 duster 4 speed hump location? [Re: hotairballoonpilot] #2745082
02/20/20 11:25 PM
02/20/20 11:25 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I think you will find that when you lay the 4 spd hump onto the new floor pan, it won't fit but in one place. Trace around it with a sharpie, and step in enough for good overlap and cut the hole. I will be adding one to my 70 Duster that was a 3 on the tree, and that is my plan. I'm seriously thing of using Fusor panel bond to hold it, and then just weld up the screw holes needed to hold it down during the bonding process.
Re: 74 duster 4 speed hump location? [Re: JDMopar] #2745090
02/21/20 12:19 AM
02/21/20 12:19 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Did a 4-speed hump in an early B, FWIW, and it did pretty much drop in one place; I'd say it had 1/4" of wiggle room.
If you can, measure or better yet mock up shifter location before welding.
That way any tolerance stack-up wouldn't bite you in the butt.
Re: 74 duster 4 speed hump location? [Re: topside] #2745274
02/21/20 05:58 PM
02/21/20 05:58 PM
South Dakota
South Dakota
thanks guys! I will plug away. In the process of getting the rear frame rail back up in place then onto the interior floor pan area.
corey
t/a challenger steering ?
by calrobb2000. 04/09/20 11:23 AM
April Showers Bring May Flowers:
by Sunroofcuda. 04/09/20 11:06 AM
early A body 273 mtr mt ?
by RapidRobert. 04/09/20 10:44 AM
tunnel rams
by copchaser. 04/09/20 10:03 AM
Moparts Recent Posts
no spark situation/firecore cd coil bad?
by RapidRobert. 04/09/20 11:59 AM
by FM3AAR. 04/09/20 11:55 AM
The official Coronavirus thread
by RMCHRGR. 04/09/20 11:55 AM
Exhaust manifolds and angle plug?!
by viperblue72. 04/09/20 11:53 AM
