Original color of alternator #2744954
02/20/20 02:51 PM
02/20/20 02:51 PM
Big G Offline OP
Big G  Offline OP
I have a 70 barracuda 383 2 barrel. Anyone know what the original color of the alternator was? Mine is blue/teal color and my research is saying aluminum color
Re: Original color of alternator [Re: Big G] #2744960
02/20/20 03:13 PM
02/20/20 03:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bare aluminum.
Re: Original color of alternator [Re: topside] #2744961
02/20/20 03:16 PM
02/20/20 03:16 PM
Big G Offline OP
Big G  Offline OP
Water pump also?
Re: Original color of alternator [Re: Big G] #2744969
02/20/20 03:41 PM
02/20/20 03:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by Big G
Water pump also?
WP is engine color
Re: Original color of alternator [Re: Big G] #2745058
02/20/20 09:49 PM
02/20/20 09:49 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Does your car have AC?
The alternator is bare aluminum but there a glob of paint on it that believe tells you what the part number is.
Re: Original color of alternator [Re: Big G] #2745140
02/21/20 10:23 AM
02/21/20 10:23 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you are asking about the alternator cases, they were bare aluminum, as already stated. I have a hint if you want to keep them looking like new and not tarnishing over time. Have a shop take the alternator apart, and then glass bead the aluminum housings to get them good and clean. Then mix a good amount of flattening agent to some clear coat. The flattening agent knocks the gloss down on the clear and since it is white, it adds a bit of tint to the clear. Be sure and spray the pieces with the spray gun far away from the pieces so that the clear is much dryer than you would normally spray it to give it a textured finish. It may take a little experimentation to get it right. But with the right combo, the finish looks nearly perfect to bare aluminum. And stays that way.
Master, again and still
Re: Original color of alternator [Re: DaveRS23] #2745368
02/22/20 01:24 AM
02/22/20 01:24 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Never glass bead blast aluminum if you want it to really look like original. Call Dixi auto to get it done correct
Re: Original color of alternator [Re: topside] #2745378
02/22/20 04:14 AM
02/22/20 04:14 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted by topside
Bare aluminum.
Not quite the correct answer. Alternators were bare aluminum but with a chromate conversion coating applied. Henkel Alodine 1201 for brush application may be the same or similar. Product description: "Nonflammable, chromic acid-based, coating chemical that will produce a chrome conversion coating on aluminum and its alloys. The coating formed by Alodine 1201 is gold to tan in color and it becomes a part of the aluminum surface."
My information comes from Jim Ridge at Dixie Restoration who does an outstanding job on restoring alternators and starters. According to Jim alternators got the coating.
Photo shows a finish other than bare aluminum with a hint of yellow or tan and a slight rainbow effect.
Re: Original color of alternator [Re: kentj340] #2745396
02/22/20 07:51 AM
02/22/20 07:51 AM
MA
steve70 Offline
steve70  Offline
MA
I agree.......here's a couple pictures of an NOS case
1970 Challenger T/A 4 speed
Re: Original color of alternator [Re: 71birdJ68] #2745431
02/22/20 10:46 AM
02/22/20 10:46 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You are wrong about that IF you intend to clear coat it. Ever done any paint and body work? The finish allows the clear to bite, same as sanding a fender or door. After clearing, the end finish very nicely duplicates the finish in the pics here. And stays that way. To only leave the finish that the glass beading leaves would be wrong. Same as leaving a fender sanded, but not painted.
But as with most of the finishes on the engine and under the body, the alternators posted here looked like that when unboxed and installed, but certainly did not look like that after just a short time of regular service. To me, most restored Mopars look like a collection of new parts fresh out of the box, not as a complete real-world car as they would have came off the transport or as they looked after just a short time of driving. You know, how they really looked 'in the wild'.
This kind of stuff usually has more to do with a particular look that the owner has in mind rather than having the car/engine look like it really did going down the road in it's prime.
Re: Original color of alternator [Re: DaveRS23] #2745438
02/22/20 11:20 AM
02/22/20 11:20 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I said if he wants it to look correct. If not he can do what he wants.They weren't clear coated either. I have talked to Jim Ridge about blasting and was told he couldn't do anything with it if it had been blasted. The thing is, once it's blasted, you can't go back and unblast it, the texture of the metal is changed for good.
Re: Original color of alternator [Re: 71birdJ68] #2745459
02/22/20 12:21 PM
02/22/20 12:21 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
A vibratory cleaner, with a user that knows what each media does is the correct answer.
Years back I ran into a rep for Wheelabrator corporation that had five such machines in his own personal pole building. bow
The guy was a car guy too. He could reproduce any surface finish on cast metal. I would give him my parts and he would drop them off to me a week later. Even had him run some tarnished supercharger blower scoops through the process and they came out looking fully polished. If you looked close with a magnifying glass you could see the micro scratches, but for a drag car, they were fine.
Re: Original color of alternator [Re: 71birdJ68] #2745514
02/22/20 03:12 PM
02/22/20 03:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
So your source's way is the only way, right? You are referring to one and only one method of refinishing. As posted above, there are other methods. I only offered a method that is very close to O.E., is easily accessible, affordable, and permanent. And my method was accepted by the judges at the Mopar Nationals. My '71 GTX was awarded 95 points and was OE Certified.
The OE Cert judges had no problem with that method of finish for that car's alternator. But you do.
As to 'correct', that is a very relative term.
Does the OP want the alternator to look like it had just been coated at the manufacturing plant? Does he want it to look like it looked off the transport? Or like it looked at the time of retail delivery, which could be months later? Or like it looked after awhile of daily driving? The pics above of an alternator after all these years is my point. Many, if not most of the finishes on our Mopars when new, did not wear well.
And as I said, I personally have never thought the temporary look of an item fresh from the manufacturer was an accurate representation of what it would look like after a short time. Whether the part sat on a shelf in inventory, or sat on a vehicle sitting at the plant, hit inclement weather on the transport on the way to the dealership, whether it sat on the dealer's lot for weeks or months, or what it looked like a short time after retail delivery.
And that doesn't even go into the issue of whether every single alternator ever produced during that era looked EXACTLY the same. We know better. Especially with Mopar.
Today, 50 years later, people argue/discuss what every item on a particular car from a particular plant looked like originally. Well, what it looked like often changed by the week and the month. And often never looked like it did the day it was actually produced by the time the new owner was actually driving the car. The finishes were simply not meant to last.
OP; pick your preferred look and go for it. Satisfy yourself, because there is no way to know just exactly what that alternator looked like at the time of that car's retail delivery.
Re: Original color of alternator [Re: DaveRS23] #2745556
02/22/20 06:25 PM
02/22/20 06:25 PM
Akron, ohio
76orangewagon Offline
Akron, ohio
Here is an NOS 1971 Alternator I picked up last year at the Mecum car auction from the Juliano collection.
Re: Original color of alternator [Re: 76orangewagon] #2745681
02/23/20 09:01 AM
02/23/20 09:01 AM
VA
dragon slayer Offline
VA
That alternator would be a 70 right. 8th week. Late 70 build.
There are restorations of cast aluminum that are glass beaded with the proper bead, cleaned, tumbled to get a more correct finish. Then can be coated with a conversion.
Frankly, if an alternator or any aluminum cast part has had oxidation and corrosion the surface has been changed. Let alone absorption of contaminants. Now you can't sand blast it and remove metal. Beading is about removing contaminants and closing pores (peening).
If you see enough alternators you will also notice a lot of mismatched parts, and those industrial tumblers used by the rebuilder would remove a lot of metal, including casting markings and the stampings. Let alone they drilled extra holes for additional field wire.
So any process can change the surface if not done properly.
Re: Original color of alternator [Re: dragon slayer] #2745782
02/23/20 03:13 PM
02/23/20 03:13 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree
Re: Original color of alternator [Re: 5carguy] #2745852
02/23/20 07:41 PM
02/23/20 07:41 PM
Akron, ohio
Akron, ohio
Here is the same alternator after Jim Ridge @ Dixie restored it.
Re: Original color of alternator [Re: 76orangewagon] #2745863
02/23/20 08:25 PM
02/23/20 08:25 PM
Kirkland, Washington
Pacnorthcuda Offline
Nice! I hate seeing bead blasted parts on high end cars! That alternator looks sweet.
Re: Original color of alternator [Re: Pacnorthcuda] #2745917
02/23/20 11:41 PM
02/23/20 11:41 PM
VA
VA
I bet there are a lot of beaded parts you don't even know where done that way. wink
Jim does do nice work.
Re: Original color of alternator [Re: Big G] #2746056
02/24/20 12:03 PM
02/24/20 12:03 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The "colour" is based on the two digits listed on your broadcast sheet under ALT(alternator). If they are 72, as most of what this thread has been showing, then it would be orange. If your 383+2 car is an A/C car, then the two digits would be 78, for 3438 178(stamped on the alternator), the colour would then be green. Is your car an original A/C car? The motor colour for your car would be originally a blue colour, being a 383+2 car.
