Re: Data request, what is your cranking PSI?
[Re: 73DAD]
#2744907
02/20/20 12:00 PM
02/20/20 12:00 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Smog 440, big old iron open chamber heads, atleast 36⁰+ of timing, any octane:
Average of all 8 hot is 142 psi
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: 73DAD]
#2744913
02/20/20 12:16 PM
02/20/20 12:16 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
The cranking pressure won't tell you much. I have an aluminum head 11:1 hemi that cranks 185 psi and runs on pump gas w/ 34°. Also have an aluminum head 14.5:1 wedge that cranks 185 psi and needs 112 fuel. The same motor w/ a different camshaft cranked 275 psi and also ran 112 fuel. Both run at 38°. Had an iron head 12:1 440 years ago that cranked 220 psi and needed 110 fuel at 38°.
[Re: Mr PotatoHead]
#2744935
02/20/20 01:56 PM
02/20/20 01:56 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
My Predatoer is fairly low, but being an aluminum block they usually are. It is 210ish per hole, Q16 fuel 39 degrees in first gear and 33 in high gear, This is a 1200HP 15.8-1 engine. When it gets freshened later this year we will be going closer to 17-1 in an effort to up the cylinder pressure. FWIW the heads up car, aluminum block again only pumps about 175, its 16.4-1 runs on C45 and we have timing curves for each gear
[Re: Al_Alguire]
#2744964
02/20/20 03:21 PM
02/20/20 03:21 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Like said, this will not tell too much. 1984 Shelby 2.2, 0.039" over flat pistons with ported Aluminum G head, 252 deg cam (0.460 lift) installed 4 deg advanced , 0.030 cut on block, true measured 11.2:1 compression ratio. 20 degrees base timing, with factory Shelby computer and knock sensor. It would show 215 PSI warm. It ran on pump SUPER. Shifted at 7200 RPM. Top speed on 85 MPH speedo was 15 MPH UPDATAED^^^
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: 73DAD]
#2744979
02/20/20 03:59 PM
02/20/20 03:59 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
10.2 to 1 in both my 493" RB & 408" Magnum. Both have aluminum heads, pistons 0 decked with high quench heart shaped chambers. The RB has reverse dome that matches the Indy EZ chambers. The Magnum has flat top pistons with Eddie heads.
Both motors crank 200 psi warm. I run 35* total advance locked in on the RB and reflashed factory JTEK computer controlled on the 408. They both run on California 91 ethanol pump swill. No detonation even on hot days.
(Installed on 105* centerline)
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: MR_P_BODY]
#2745028
02/20/20 07:28 PM
02/20/20 07:28 PM
Posts: 10,003 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have a H ones inverse ground roller cam and he uses VERY long lash ramps. If you are a few degrees off when setting lash it can make a noticeable difference in opening point. Add to that aluminum block and heads and things must change a bunch from running cold to hot.
[Re: 73DAD]
#2745038
02/20/20 08:06 PM
02/20/20 08:06 PM
Posts: 4,206 New York
polyspheric
New York
Not enough data: missing IVC closing ABDC, rod ratio, intake vacuum during test. CCP is useful to compare the same (or almost identical) engine(s) with different tunes, not to compare different engines.
Boffin Emeritus
[Re: 73DAD]
#2745092
02/21/20 12:28 AM
02/21/20 12:28 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Hughes Engines HE3844AL hydraulic flat tappet cam, specs are: see attachment.
This is in a semi-blueprinted 360 block at 10.5:1 CR, cranking some 185 PSI @hot.
Engine runs on 91 pump gas, 21 initial and 38 total mechanical advance.
[Re: Diplomat360]
#2745211
02/21/20 01:17 PM
02/21/20 01:17 PM
Al_Alguire
Las Vegas
The two examples I listed might scare to many in here if they knew the cam specs
[Re: 73DAD]
#2745307
02/21/20 08:43 PM
02/21/20 08:43 PM
polyspheric
New York
The same CCP can be arrived at by many different combinations of CR & IVC, like late IC + high CR or early IC + low CR may produce the same CCP at cranking speed. The cylinder combustion pressure of the low CR will rise immediately but not that much, the high CR will take longer (delayed VE and torque curve) but get much higher. Two engines with the same CCP, produced the same way, may not have the same knock sensitivity.
Things to avoid: using the wrong cam (not the optimum choice for best power characteristics) to change cranking pressure.
Overlap has nothing to do with CCP, but it definitely affects knock sensitivity by retaining exhaust gas in the chamber.
Boffin Emeritus
[Re: polyspheric]
#2746011
02/24/20 09:43 AM
02/24/20 09:43 AM
an8sec70cuda
It seems to me that the OP is trying to judge what octane you can run by the cranking compression of the engine. That's not gonna work.
[Re: an8sec70cuda]
#2746100
02/24/20 02:27 PM
02/24/20 02:27 PM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
It seems to me that the OP is trying to judge what octane you can run by the cranking compression of the engine. That's not gonna work. I didn't say that, nor imply it. Thanks to all those that have contributed to the thread.
