My Predatoer is fairly low, but being an aluminum block they usually are. It is 210ish per hole, Q16 fuel 39 degrees in first gear and 33 in high gear, This is a 1200HP 15.8-1 engine. When it gets freshened later this year we will be going closer to 17-1 in an effort to up the cylinder pressure. FWIW the heads up car, aluminum block again only pumps about 175, its 16.4-1 runs on C45 and we have timing curves for each gear
