What is your cranking PSI? Please specify hot or cold.
What octane can you run? How much advance are you running? What combustion chamber? Alum or Iron heads?
The more info the better, thanks!
I plan on doing a cranking pressure test to see if I'm high or low. The problem is, I have no frame of reference for this & would like to hear what others have. I'd bet there are plenty of others on this forum that would find this information interesting or useful too.
