8 3/4 to a Dana
#2744472
02/19/20 01:51 AM
02/19/20 01:51 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
I am going to order up a Dana 60 for the Scamp I am assuming will need to get a new drive shaft? Info appreciated
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: 8 3/4 to a Dana
[Re: Stroker Scamp]
#2744474
02/19/20 02:13 AM
02/19/20 02:13 AM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
I am going to order up a Dana 60 for the Scamp I am assuming will need to get a new drive shaft? Info appreciated When I did the swap had to get the shaft shortened, get the 60 installed & see if the old shaft fits, if not measure & get it fixed.
Re: 8 3/4 to a Dana
[Re: Stroker Scamp]
#2744494
02/19/20 08:21 AM
02/19/20 08:21 AM
Posts: 1,772 Keymar, MD
DusterKid
Keymar, MD
I am going to order up a Dana 60 for the Scamp I am assuming will need to get a new drive shaft? Info appreciated If rear ends are installed in the same location your drive shaft will have to be shorten.
Re: 8 3/4 to a Dana
[Re: DusterKid]
#2744505
02/19/20 09:09 AM
02/19/20 09:09 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I am going to order up a Dana 60 for the Scamp I am assuming will need to get a new drive shaft? Info appreciated If rear ends are installed in the same location your drive shaft will have to be shorten. Somewhere around an inch if I recall correctly.
Re: 8 3/4 to a Dana
[Re: Stroker Scamp]
#2744514
02/19/20 09:41 AM
02/19/20 09:41 AM
Posts: 4,206 New York
polyspheric
New York
Is the pinion stem at the same vertical height? The Ford 9" is lower, affects the angle.
Boffin Emeritus
Re: 8 3/4 to a Dana
[Re: 340Cuda]
#2744596
02/19/20 01:10 PM
02/19/20 01:10 PM
polyspheric
New York
IIRC a test was run with an 8-3/4 vs. 60, and the ET was really close. The extra efficiency almost exactly made up for the extra 75 lb. weight gain. IDR anything easy that saves weight on the Dana, though. Smaller brakes?
Boffin Emeritus
Re: 8 3/4 to a Dana
[Re: polyspheric]
#2744603
02/19/20 01:28 PM
02/19/20 01:28 PM
Posts: 1,291 Tucson AZ,
MadMopars
Tucson AZ,
IIRC a test was run with an 8-3/4 vs. 60, and the ET was really close. The extra efficiency almost exactly made up for the extra 75 lb. weight gain. IDR anything easy that saves weight on the Dana, though. Smaller brakes? Although I don't have the weights in front of me, going with a spool should be worth something.
Re: 8 3/4 to a Dana
[Re: an8sec70cuda]
#2744621
02/19/20 02:26 PM
02/19/20 02:26 PM
Posts: 25,784 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If rear ends are installed in the same location your drive shaft will have to be shorten. Somewhere around an inch if I recall correctly. 1 1/8" to be exact Centerline of Axle Shaft to Center of Universal Yoke 8 3/4" 12.35" 9 3/4" 13.47"
Re: 8 3/4 to a Dana
[Re: John_Kunkel]
#2744850
02/20/20 08:53 AM
02/20/20 08:53 AM
an8sec70cuda
Going from a locker/suregrip to a spool in a Dana is worth something like 20 lbs. Might be more than that actually.
