Re: solid motor mounts - poly or rubber trans mount ?
[Re: moparx]
#2743590
02/16/20 02:43 PM
02/16/20 02:43 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I went with the PST urethane mount and wish I would of done it years ago after the rubber would deteriorate after a few years and sag......
[Re: Thumperdart]
#2743597
02/16/20 02:50 PM
02/16/20 02:50 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I've been using solid engine mounts and a poly trans mount for years. Thinking about going back to rubber isolator and a strut on the engine, getting old I guess
72 Plymouth Roadrunner 11.08@123.25
[Re: moparx]
#2743613
02/16/20 03:27 PM
02/16/20 03:27 PM
Posts: 2,917 A shed in England
Tig
A shed in England
Ears, a poly 'box mount and fore / aft limiters. Been this way since I installed a 440 in '94
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: moparx]
#2743734
02/16/20 08:29 PM
02/16/20 08:29 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
Rubber on the tranny mounts as that was the only option back when I put my last car together in 2002 . My current SP CM tube chassis car has a aluminum front motor plate with a bolt in mid plate and a rubber mount on the Powerglide tranny I'm building a new 1965 Dart back half car that is certified to 7.50 ET but I have not dealt with the tranny mount yet, I'm thinking of using a solid front and mid plate and no tranny mount on either a Powerglide or a all out Pro Trans 727 SS trans
[Re: Cab_Burge]
#2743791
02/16/20 10:59 PM
02/16/20 10:59 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
I have a motor plate and poly trans mount in my Valiant.
[Re: Cab_Burge]
#2743914
02/17/20 12:28 PM
02/17/20 12:28 PM
Posts: 4,069 Mo.
racerx
Mo.
Rubber on the tranny mounts as that was the only option back when I put my last car together in 2002 . My current SP CM tube chassis car has a aluminum front motor plate with a bolt in mid plate and a rubber mount on the Powerglide tranny I'm building a new 1965 Dart back half car that is certified to 7.50 ET but I have not dealt with the tranny mount yet, I'm thinking of using a solid front and mid plate and no tranny mount on either a Powerglide or a all out Pro Trans 727 SS trans Even in a 25 series chassis ,there still needs to be a poly/rubber tranny mount?
[Re: Blucuda413]
#2744154
02/18/20 06:25 AM
02/18/20 06:25 AM
Posts: 4,069 Mo.
racerx
Mo.
One item I didn't mention is that I run a JW trans case including a JW tail shaft housing. I'm sure there's extra strength there. curios on what chassis this is in? Stock/probuilt?
[Re: moparx]
#2744509
02/19/20 09:21 AM
02/19/20 09:21 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I use a poly trans mount. Same one has been on the car for 23 years now. I've always been told not to run a solid trans mount so you have some amount of "give", but can't argue w/ blucuda's success. Every time I've seen someone locally try that, they ended up cracking the trans case.
[Re: an8sec70cuda]
#2744619
02/19/20 02:24 PM
02/19/20 02:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
ALL cars flex... any two points is a straight line buy if you add a third point it doesnt mean its still a straight line.. same thing goes on a car.. you need to have one point that will give..if not you will break the weakest point.. I run the front motor plate and a mid plate with a rubber trans mount
