Re: Hemi head question
[Re: sixpakdodge]
#2741889
02/11/20 11:31 AM
02/11/20 11:31 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Post some pics so we can see them.
[Re: sixpakdodge]
#2741901
02/11/20 12:21 PM
02/11/20 12:21 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve only had a couple sets of Stage V hemi heads in my shop.
If purchased as “bare heads”, they are very far from being ready to run.
I had flowed one in a semi-finished state way back(no porting), and they were rather unimpressive like that. It was clear that wasn’t how they were intended to be used.
I’m sure a proper valve job, along some bowl work and blending the cnc’d opening into the runners will perk them right up.
[Re: Youngblood]
#2741916
02/11/20 12:51 PM
02/11/20 12:51 PM
an8sec70cuda
with what they said, lol. Those are very good heads when done right. Probably bought bare and done up by who knows...obviously not very well. BTW...I don't think there are any Chinese knock-off hemi heads on the market.
[Re: an8sec70cuda]
#2741925
02/11/20 01:05 PM
02/11/20 01:05 PM
fast68plymouth
So. Burlington, Vt.
What I’ve seen with regards to stock, or “stock type” Gen II hemi heads is........ they don’t flow as well as what many people think they flow...... without fairly substantial porting done to them.
Stock 559’s with only the valve job touched up are a little over 300@.700. The MP 559 replacements can be about 15-20 better, depending on which version 559-M it is.
The Ede made MP heads are in the 320 range ootb.
The Indy SR with a VJ and very mild bowl blend is in the mid-330’s.
The basic shapes of the ports are good on all the heads. So, after they get the seats redone and bowls blended....... if you’re looking for a significant improvement in flow....... they just need to be made “bigger”.
If you’re building something with enough cubes to utilize a bigger head..... the assembled Ede Victors are over 400cfm ootb.
[Re: Youngblood]
#2741998
02/11/20 03:58 PM
02/11/20 03:58 PM
fast68plymouth
So. Burlington, Vt.
I totally get where you’re coming from.
I’ve had my hands on some heads off pretty high dollar builds that I wasn’t too impressed with.
Those “what were they thinking” moments.
I wouldn’t mind seeing some pics of the valve job and bowls as they were.
[Re: fast68plymouth]
#2742020
02/11/20 05:29 PM
02/11/20 05:29 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I wouldn’t mind seeing some pics of the valve job and bowls as they were. Probably thinking I hope the check clears before he realizes what I sold him... Kevin
[Re: Youngblood]
#2742031
02/11/20 06:02 PM
02/11/20 06:02 PM
Posts: 421 montana
BANDIT
montana
Not who I’m thinking off then, he would have charged more than 30k. Lol. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: 469runner]
#2742547
02/13/20 11:48 AM
02/13/20 11:48 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
This is what Stage V heads should look like after they have been prepped properly. Who did the seal groove for you?
[Re: RATTRAP]
#2742716
02/14/20 02:39 AM
02/14/20 02:39 AM
Posts: 1,249 North Carolina
469runner
North Carolina
This is what Stage V heads should look like after they have been prepped properly. Who did the seal groove for you? Tim Banning at For Hemi's Only prepped these heads. First class work.
[Re: RATTRAP]
#2742723
02/14/20 07:44 AM
02/14/20 07:44 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
This is what Stage V heads should look like after they have been prepped properly. Who did the seal groove for you? I have a customer in Dalton Ga that wrote the program and did mine. It saved me a lot of money.
