426 Hemi Rockers Hitting Valve Covers? #2741630
02/10/20 04:50 PM
02/10/20 04:50 PM
N.Y.
sixpacksteve Offline OP
N.Y.
other than doubling up on gaskets,
is there another fix?
there Stage V rockers
Hell Hath No Fury Like Mine
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741687
02/10/20 06:32 PM
02/10/20 06:32 PM
If it is hitting the stock steel baffles only dent them or drill them out where they are hitting. scope
If there hitting away from the baffles replace those covers with taller ones twocents
Another reason I refer to the 426 C.I. Elephant motors as "hemiroids" whistling grin
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: Cab_Burge] #2741710
02/10/20 07:23 PM
02/10/20 07:23 PM
N.Y.
N.Y.
ok Who makes a taller valve cover?
just want a chrome one.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741712
02/10/20 07:26 PM
02/10/20 07:26 PM
N.Y.
N.Y.
What about the tubes?
don't they need to be longer?
who would have those?
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741760
02/10/20 10:39 PM
02/10/20 10:39 PM
Probably not going to find good steel TALLER V.C. any where scope
Maybe some cheaper chrome steel valve covers but may regret buying them shruggy
As far as the plug tubes I've had the bottoms rip out from wear on stock iron heads so I installed a set of Milidon spark plug tube seals that worked okay usually, not always though whiney shruggy
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: Cab_Burge] #2741772
02/10/20 11:16 PM
02/10/20 11:16 PM
N.Y.
N.Y.
Cab, if i add a gasket how about putting a washer on bottom of tube the same thickness as gasket to make the difference?
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741773
02/10/20 11:22 PM
02/10/20 11:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You could use these.Spacers
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: NITROUSN] #2741783
02/11/20 12:17 AM
02/11/20 12:17 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not Hemi but how I fixed mine.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: 62maxwgn] #2741819
02/11/20 07:40 AM
02/11/20 07:40 AM
N.Y.
N.Y.
removed valve cover and were 2 marks on baffle.
used ballpen hammer to fix that .
but still taping between 2-4 spark plugs.
i have the milodon tube seals and forever gaskets.
if i use the mancini spacers will they cause them to leak?
and should i use a washer to make up difference of spacer?
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741826
02/11/20 08:10 AM
02/11/20 08:10 AM
P
PasiR Offline
PasiR  Offline
P
Contact Tim @ FHO for longer tubes.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: PasiR] #2741851
02/11/20 09:28 AM
02/11/20 09:28 AM
an8sec70cuda Offline
You could use the Indy aluminum covers and stock tubes. They have the thick boss for the dual plug setup that needs some clearancing (did on mine anyway), but they clear everywhere else.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741870
02/11/20 10:34 AM
02/11/20 10:34 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
On mine, the exhaust rockers were hitting the valve cover an inch or so above the head. Took several tries at spraying some paint inside the covers and running the engine enough to mark the paint, then dimple a bit and repeat. My covers are wrinkle, so the dimples aren't really noticeable.
Master, again and still
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: PasiR] #2741873
02/11/20 10:40 AM
02/11/20 10:40 AM
N.Y.
N.Y.
For future Folks!
just contacted tim at FHO and he has the kit with gaskets and Longer tubes.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741876
02/11/20 10:46 AM
02/11/20 10:46 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
There are two other options on steel covers. OEM Nascar covers had clearance for the 2" valve gear, and then John Arruzza used to make steel covers in chrome and black wrinkle that were specifically designed for Stage V rocker clearance. Occasionally he still lists them on eBay.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741900
02/11/20 12:19 PM
02/11/20 12:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Andy F prototyped some valve cover spacers quite awhile back....but I don't know which dealer he intended to sell the product
so you might have to dig or just ask Andy who sells them.
Judging from the MREAR part number on mancini's site, it's probably Mancini but to be honest I just don't remember.
I had them in my hand and they fit pretty darn nicely, but I will probably use taller valve covers if there are clearance issues.
Rich H.
Esse Quam Videri
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2741917
02/11/20 12:51 PM
02/11/20 12:51 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Disregard all crazy ideas. There are valve covers that work. I used to get them from Arruzza. But the last engine I put together with Stage V rockers a few months ago, we used those nearly free chrome valve covers on ebay from newyorkrestomod or something like that. Buy those. They work. They are nearly free. And they look good. Anything else is a bad idea.
2011 Drag Pak Challenger
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: rickseeman] #2741923
02/11/20 12:59 PM
02/11/20 12:59 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
I had the same problem, I bought a pair of Stage V covers. No more problems, very nice fit and finish.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: hemi471] #2741926
02/11/20 01:05 PM
02/11/20 01:05 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Maybe just me but have never liked any cover except the stock ones. Even dented up ones look good, something about the shape.
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: cudaman1969] #2744490
02/19/20 07:56 AM
02/19/20 07:56 AM
N.Y.
N.Y.
OK, just recieved the gasket and longer tube set from FHO.
cometic gaskets and quality tubes.
Only problem spark plug wires are Now too short!
i guess i'll need a straight boot!
any recomendations?
Re: 426 Hemi Rockers Hitting Valve Covers? [Re: sixpacksteve] #2744630
02/19/20 03:02 PM
02/19/20 03:02 PM
any recomendations?
I'm assuming your referring to the distributor wire ends, correct?
If so they will make the plug wire end even shorter, don't do that tsk
if your saying on the plug end all the early and 426 Hemi plug wires only have straight ends on them to fit into the plug and wire insulators shruggy
Don't we love our Hemiroid motors whistling grin
