AAR Lower Shock Mount #2741573
02/10/20 02:19 PM
02/10/20 02:19 PM
Ashland City, Tennessee
Aar1064 Offline OP
Aar1064  Offline OP
I originally put a set of KYB's on my AAR but they are really to stiff for me. The most popular replacement is Monroe's so I ordered a set. When it came time to install on the lower mount I realized that the eyelet on the Monroe was to wide. After reaching out to a couple of more knowledgeable folks, I learned that I needed to remove the sleeve from the lower mount shaft in order to install the Monroes. I did more research and saw a set of NOS 3400854 shocks on Ebay. According to my broadcast sheet, 54 is in the box for the rear shocks. A quick look in parts book indicated that the correct number is 3400854 which is high performance for small and big blocks for 1970. The 3400854 shocks have a more narrow eyelet hence the reason for the sleeve.
Has anyone else ever seen a sleeve like this on their cars?
Appreciate the input
Monroe Shock
Sleeve on shaft
NOS 3400854 Shocks
Re: AAR Lower Shock Mount [Re: Aar1064] #2741639
02/10/20 05:09 PM
02/10/20 05:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: AAR Lower Shock Mount [Re: mopars4ever] #2741696
02/10/20 06:45 PM
02/10/20 06:45 PM
MA
steve70 Offline
steve70  Offline
MA
A couple pictures from my T/A before restoration
1970 Challenger T/A 4 speed
Re: AAR Lower Shock Mount [Re: mopars4ever] #2741719
02/10/20 07:47 PM
02/10/20 07:47 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Never seen that sleeve
Re: AAR Lower Shock Mount [Re: AARCONV] #2741860
02/11/20 10:00 AM
02/11/20 10:00 AM
moparx Offline
moparx  Offline
i believe that "sleeve" is a leftover from a "????" brand of shock. it needs to come off.
i have swapped a ton of shocks in the last 50+ years, and ALL of the mopar shock studs did NOT have that "sleeve".
this includes all makes and models, including 1/2 & 3/4 ton shocks.
beer
Re: AAR Lower Shock Mount [Re: moparx] #2741966
02/11/20 02:52 PM
02/11/20 02:52 PM
Aar1064 Offline OP
Aar1064  Offline OP
I removed the sleeves yesterday and all is good.
Thanks for all the replies.
