'71 Dart & min-tubs how much tire will fit? #2740705
02/07/20 04:25 PM
02/07/20 04:25 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
does this look like it will work?
does this look like it will fit?
single choice
Votes accepted starting: 02/07/20 04:24 PM
You must vote before you can view the results of this poll.
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2740731
02/07/20 05:34 PM
02/07/20 05:34 PM
Guitar Jones Offline
You can get about 15" of tire width from the frame rail to the fender, if you roll the lip and push the quarter out a little but the real issue is the wheel opening. Without stretching that no way you will get that to fit.
Re: '71 Dart & min-tubs how much tire will fit? [Re: Guitar Jones] #2740778
02/07/20 08:34 PM
02/07/20 08:34 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Sure, all it takes is money ! laugh2
Definitely will have to stretch the wheel opening length.
Not sure if that rear axle is too wide, looks that way.
More info would be handy, unless you're just kidding.
13x31s ride under my Duster using its original rear rails.
Worst case, new rails further inboard, tubs and some under-car cussing...
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2740785
02/07/20 09:26 PM
02/07/20 09:26 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
With mini-tubs and 10" rims, 325/50-15 tires will just fit if you have the right backspacing (7.25" for a stock A-body width 8-3/4).
I have 295/50 on mine and there's loads of room. Well, "loads" relative to most things on an A-body project wink
Re: '71 Dart & min-tubs how much tire will fit? [Re: DrCharles] #2740812
02/07/20 11:25 PM
02/07/20 11:25 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
it's 325/50/15s on 15x10s with 3-1/2" backspacing - yes, it fits boogie
when I mocked it up on the jack stands, realcrazy I thought NO WAY!! what did I miss blush
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2740824
02/08/20 12:19 AM
02/08/20 12:19 AM
A collage of whims
A collage of whims
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2741068
02/08/20 08:54 PM
02/08/20 08:54 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Are those the "Shelby 500" slot mags ?
Re: '71 Dart & min-tubs how much tire will fit? [Re: hemienvy] #2741083
02/08/20 09:52 PM
02/08/20 09:52 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
they are U.S. Mags (reproduction U.S. Indy Aluminum Slot Mags) from Summit
15x5 front w/2.5" backspace 15x5 US INDY
15x10 rear w/3.5" backspace 15x10 US INDY
I think the rear axle housing ended up 50-3/4" flange-to-flange
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2741086
02/08/20 10:01 PM
02/08/20 10:01 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Those 325/50 15's are a bit shorter ( - 0.19") but 2 inches wider than the 275/60 15's I have under my stock wheelwell 1965 Barracuda. wink
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: '71 Dart & min-tubs how much tire will fit? [Re: Dave_J] #2741092
02/08/20 10:11 PM
02/08/20 10:11 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
up this Dart had 275/60/15s on 15x7.0" Rallye wheels before the sawzall & weld commenced biggrin
Re: '71 Dart & min-tubs how much tire will fit? [Re: 6bblgt] #2741324
02/09/20 06:39 PM
02/09/20 06:39 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
How much did you end up "stretching" the rear wheel wells?
Plymouth Makes It!
Re: '71 Dart & min-tubs how much tire will fit? [Re: RoadRunnerLuva] #2741446
02/10/20 12:06 AM
02/10/20 12:06 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
a chassis shop moved the inner rear wheel well in flush with the frame rail, where the Caltracs were/are mounted - the outer wheel well is "radiused" to remove the "hump" just above the wheel lip
AFAIK the rear wheel lip is the stock profile with stock wheel lip mouldings, the lips are hammered & trimmed - I will confirm how wide the added material is in the wheel well
